TechPB Forum: what are your coolest spyder projects - TechPB Forum
#1 User is offline   mydisplayname
Posted 04 February 2013 - 10:30 PM
What are some of your coolest spyder mods such as spumps spimmys ect. I have built a spump and want to know what else i can build. i would like to see pictures of your projects to help me create ideas.
#2 User is offline   Steephill
  • Dota 2 > Life itself
Posted 04 February 2013 - 10:37 PM
Spump. If I had money I would have built a spimmy. Only thing I need for my Spump is the pump handle, it's the 09 model without a threaded lpr so I'm having trouble finding something that'd slide over the barrel and still have room for my metal dowl pump rod to go into.
My Feedback +13/-0
`kook, on 01 February 2012 - 06:06 PM, said:
The gold standard isn't what is most popular.By that logic, Justin Beiber is the gold standard of music.
#3 User is offline   mydisplayname
Posted 05 February 2013 - 07:06 PM
i used 3/4 inch inner diameter pvc for mine and thin put a 1 1/4 inch peace over it and made a tight hole to fit the rod in between he two peaces. not to hard
#4 User is online   Wolfe
Posted 05 February 2013 - 07:17 PM
Been planning both a Spump and a Spimmy. Just having trouble finding the right parts. I need to look in places other than Ebay and Craigslist. Always overpriced.
#5 User is offline   Steephill
Posted 05 February 2013 - 08:01 PM
Thanks! That's all I need Posted Image
My Feedback +13/-0
#6 User is offline   madsnipes
  • Zef Member
Posted 05 February 2013 - 09:12 PM
Just wait until I get my hammer 7...
Pics will be posted...
#7 User is offline   mydisplayname
Posted 05 February 2013 - 09:18 PM
alright cant wait to see it
