TechPB Forum: cp 2 piece barrel - TechPB Forum
cp 2 piece barrel Which one?
#1 User is offline   Hyrinmaru
Posted 07 February 2013 - 10:41 PM
I have 2 cp barrel back which are .685 and .679 and a 14 inch cp front barrel and I was wondering how do I know to use one or the other? confused!
#2 User is online   asthmaticrhino
  • Skyrockets in flight! Beeewwww
Posted 08 February 2013 - 12:48 AM
Depends on what you are trying to do, and the size of your paint. If you are trying to underbore (paint smaller than barrel, = increased efficiency), then the ball should get stuck in the back, then you should be able to blow it out with a good puff. If you are trying to overbore(worse efficiency, but better in cold, or on brittle paint) then the paintballs should just barely roll through.
It really depends on your paint, and the conditions you are playing in. One is not more "accurate" than the other.
bigx, on 20 May 2013 - 09:45 PM, said:
#3 User is offline   Orange Chicken
Posted 08 February 2013 - 12:52 AM
Well to sum it all up easily:
Use the .685 for general use, and use the .679 if you have smaller paint or want to underbore.
#4 User is offline   Hyrinmaru
Posted 08 February 2013 - 09:53 AM
So you mean I can underbore anytime? And is it a good idea?
#5 User is offline   Orange Chicken
Posted 10 February 2013 - 03:10 PM
Yeah pretty much, as long as it isnt an extreme underbore like, like -.009 or something. But underboring and oveboring, you choose. It doesnt make a noticable or appreciable difference.
#6 User is offline   tallsmallboy44
  • Space Cowboy
Posted 10 February 2013 - 03:13 PM
It gives more consistent chronograph readings. Pretty appreciable difference if you ask me.
Feedback 2/0/0
#7 User is offline   Orange Chicken
Posted 10 February 2013 - 03:15 PM
Not accuracy wise really though.
#8 User is offline   tallsmallboy44
  • Space Cowboy
Posted 10 February 2013 - 03:31 PM
I never said anything about accuracy.
Feedback 2/0/0
