TechPB Forum: Getting an Empire Sniper! Any tips for me? - TechPB Forum
#1 User is offline   GeezusPB
  • Stud Muffin
Posted 21 March 2013 - 10:24 AM
Ok, I finally got around to a pro shop to end the debates of whether or not I should get an empire sniper. I held it in my hands and immediately fell in love with it. So anyways, I am picking it up some time next week. Is there any tips, tricks, or advice you would reccomend for me? What lube would you reccomend? Thanks in advance!
#2 User is offline   Panda Man
Posted 21 March 2013 - 10:32 AM
It's a pump so it's pretty basic for maintenance... just keep her lubed and fed. :P
#3 User is offline   GeezusPB
  • Stud Muffin
Posted 21 March 2013 - 11:13 AM
^^^Thank you sir :)
#4 User is offline   bassfisher
Posted 21 March 2013 - 12:33 PM
Time the auto trigger, it becomes pretty fast when you do. Also, planet eclipse detents drop right in.
Carolina Riot Scenario Team
#5 User is offline   get.lit.up!
Posted 21 March 2013 - 06:05 PM
Use gog gr33se to lube. And you can plug the gauge and use the gauge as a pressure tester
#6 User is offline   paintballguy2255
Posted 21 March 2013 - 09:53 PM
Don't break it is pretty good smartass advice :) .But really do what most above said,time the AT as it can be finnicky when not done properly.Not that its hard(thats what she said),but it is good to do.And I personally can't stand having things stick out of the reg/asa,so taking the gauge off is a good suggestion aswell.
#7 User is offline   natezthekid
Posted 22 March 2013 - 08:25 AM
Don't oil any thing on it, it is best to run it dry. Grease the reg once a year.
#8 User is offline   natezthekid
Posted 22 March 2013 - 08:28 AM
#9 User is offline   GeezusPB
  • Stud Muffin
Posted 22 March 2013 - 09:14 AM
Thanks for the replies guys!
