TechPB Forum: Inline Reg Results - TechPB Forum
Inline Reg Results Inline regs
#1 User is offline   azreal
Posted 28 March 2009 - 10:01 AM
Short and sweet, any of the regs I tested would work well with anything in that pressure range. You might see a small FPS drop with some of them.
Also ignore sidewinder 31, need to rebuild it to remove that one.
If I was to choose the best among them, Fatty, 2liter, Planet Eclipse. Also going to give the CP a second run since I bet I was approaching 1.5k mark in the tank which is DEATH to any of the regs.
The most interesting results were not the regs themselves, they all did good to excellent. Of course granted this is on my gun, at ~245psi, your mileage may vary. Maybe in a few weeks I will grab an ion and some cheaper stock regs and throw them on there and do a test at sub 200 psi. I also did a test run with my poppet valve and the differences were a bit different, not as much of a downward spike and such so I decided to just test on a worst case scenario. IE 15bps on an spooler. If it could work well in that situation it would work well in most any.
Now what was the most interesting thing, tank pressure. Screw in tanks are horrendous when it comes recharge at around 1.5k and below. Of the 3 I have none have done that well below 1.5k, more testing to follow, I can generally only test 2 every two weeks so taking some time. I have a conquest and old manifold maxflo, going to see if they exhibit the same behavior. So short and sweet, if you drop down below 2k psi, fill up your tank!
http://www.ppog.org/...g/results.shtml
#2 User is offline   brycelarson
  • Show me the Data!
Posted 28 March 2009 - 10:04 AM
nice work man, I'll spend some time and then will prob have questions.
#3 User is offline   azreal
Posted 28 March 2009 - 10:12 AM
In terms of what low tank pressure can do take a look at this sidewinder graph at below 1.5k
To this one at above 2k
#4 User is offline   Troy
  • What... is the air-speed velocity of an unladen swallow?
Posted 29 March 2009 - 08:18 AM
Errrr.... having trouble downloading the .CSV file. It looks to me (I'm trying to build a graph to confirm this) that some regs work better at different pressures. I think the fatty is the best example of this so far.
\m/
#5 User is offline   slinkyaroo
  • Yes, I'm old. Yes, I'm cranky.
  • Group: Root Admin
Posted 29 March 2009 - 08:51 AM
Can you compare high output and low output tanks? What did you use here?
#6 User is offline   azreal
Posted 29 March 2009 - 11:42 AM
Troy, most definetly regs perform differently at different pressures. You can only make a good comparison among the groups, ie all the ones in the DM7 group, all the ones in the excalibur group.
Going to have tank regs on down the line.
Az
#7 User is offline   Lord Odin
  • 3 may keep a secret if 2 of them are dead
Posted 29 March 2009 - 12:59 PM
Az
Az, do you plan on adding any HP (+400 psi) setups to be compared as well? So far, they appear to all be in the same vicinity of pressure. It seems like the differences in performance might be coming from how the marker utilizes the air.
Seeing how the Ninja tank regs perform would be pretty nice to see.
#8 User is offline   azreal
Posted 29 March 2009 - 03:52 PM
Eventually, I need to pick up a marker that shoots at 400psi, I have my cocker but I need something I can setup at 15bps full auto. Do any of the spyder-like markers run like that?
I talked with Ninja but they never got back with me.
This post has been edited by azreal: 29 March 2009 - 03:53 PM
#9 User is offline   UV Halo
  • Bringing the Big Guns to LLVI
Posted 29 March 2009 - 05:25 PM
I think a spyder with a very high performing LP valve, lightened hammer and a spring kit might get that low. If I remember correctly my tippy m98C with low pressure kit (no RT or cyclone) shot that low. I can't confirm for you now though.
EDIT: You'll need a Custom Pro with an electronic trigger upgrade for 15BPS though
This post has been edited by UV Halo: 29 March 2009 - 05:30 PM
Markers I shoot:
T9.1SD "Totmacher"| Woodstalker Ion MK-II | SP-1 W/Qloader
Reference Threads:
First Strike Field Listing |
External Ballistics Primer
#10 User is offline   Z3R0
  • Spontaneous Hate Machine
Posted 29 March 2009 - 05:52 PM
Nice to see some results of the SST there. Looks like it performed pretty solid.
-Z3R0
06 Cyborg, Grey Ghost 2006, PM8, Classic Automag
Proto Matrix Owners Group
#11 User is offline   Troy
Posted 29 March 2009 - 06:37 PM
Hmmm... if you can't find anything to borrow near you, then I might be willing to let you borrow my A5, it could be made to shoot that high (it's at 300psi currently). I would need some sort of collateral... but surely you'll be able to find something closer to home.
I'm in Oklahoma btw.
\m/
#12 User is offline   Lord Odin
Posted 29 March 2009 - 08:00 PM
Personally, I'd rather see a HP Tippmann or equivalent marker that is over 600 psi because there are quite a lot of people that don't go below that. Even below 400 psi is pushing it for a LPK (low pressure kit) on an A5/X7. I have enough spare parts to send my extra gun but I don't have an extra e-grip. You could keep that in mind for the test.
#13 User is offline   Jack Wood
Posted 30 March 2009 - 05:49 AM
Hi Matt,
Just an observation, but in the data you don't make it clear that some of the tests are with the tank pressure below 1.5k.
eg, if you scroll down the page, the first Ego8 reg test you come to shows the regulator REALLY sucking!! But there is no comment about the tank pressure. It just looks like the reg is crap.
As always, the testing is really good. But I think you need to spend a few minutes labeling and formatiing the data, and laying it out in an easy to follow form. At the moment it just jumps around all over the place, and there is no real explanation about what we are looking at.
Maybe a couple of pics of the set-up and the equipment used would be nice too.
Jack
I hereby declare that I work for Planet Eclipse Ltd
I live in England.
I work in England.
I am English.
Eclipse Owners Club V2
#14 User is offline   Jack Wood
Posted 30 March 2009 - 06:06 AM
View PostCrazyLittle, on Mar 30 2009, 11:37 AM, said:
This came from Pirate Mafia over on PBN:
Quote
A = pressure prior to shot, in PSI
B = lowest pressure during shot, in PSI
C = % pressure drop
D = recovery time 95% of pressure in MS
NAME / A / B / C / D
ACI bulldog / 710 / 487 / 31% / 122ms
Armageddon / 807 / 661 / 18% / 90ms
Centerflag / 801 / 675 / 16% / 14ms
Crossfire / 770 / 662 / 14% / 10ms
DYE throttle / 830 / 573 / 30% / 173ms
EVIL Scion / 556 / 472 / 15% / 18ms
Guerrilla Air Myth / 653 / 597 / 8% / 7ms
Ninja Paintball / 804 / 714 / 11% / 8ms
Pro Toyz / 804 / 508 / 26% / 41ms
Pure Energy / 840 / 724 / 14% / 10(30*)ms
WDP A.I.R. / 797 / 648 / 19% / 45ms
This was posted over in the Creepy Regs thread.
This list means nothing in the context we are talking about here. Really, the recovery and percentage drop need measuring across a range of tank pressures. For the results posted here, we have no idea what the tank pressure was for each test/reg.
What I can say for sure, is that there was no way that those are the fingures for a Pure Energy or Ninja reg with only 1300psi in the tank!!
I live in England.
I work in England.
I am English.
#15 User is offline   brycelarson
  • Show me the Data!
Posted 30 March 2009 - 07:04 AM
Hit up Eric Wang at Azodin - that might get you a 15 bps, mid to low pressure gun.
#16 User is offline   azreal
Posted 30 March 2009 - 08:49 AM
Jack, yeah its on my todo list, actually to go through all the results and add more comments. I may get to it today at work if its quiet ;) . The SST was good, but not defining like the 2liter was. Of course all the regs did adequate enough, some a bit more than others. I was even considering buying the one AKA sent me but I hate that lower fitting. The bulbousness of it.
#17 User is offline   azreal
Posted 30 March 2009 - 10:55 AM
Added comments, also I was wondering why it looked like crap. Then I remembered it needs the css style sheet, so now it looks much better, though still crappy ;)
Let me know other suggestions/comments.
#18 User is offline   Snipez4664
Posted 30 March 2009 - 12:07 PM
It's a very creepy reg. :dodgy:
This post brought to you by: Lurker
Owner/Operator/Lead Engineer - Lurker Paintball
Check out our products at Lurker Paintball
#19 User is offline   ktap
  • You just got DUSTed.
Posted 30 March 2009 - 04:49 PM
both the azodin zenith and the spyder electra run at about 300-350 psi, i'm not sure if that's low enough for the testing bryce wants done. however if you go and talk to any of the locals (<GOD>, DFsniper, Lamorte, Mrpurplehawk, to name a few) over on the kingman pages on PBN you will find many custom spyders that run comfortably in the the 400psi range. LP setups have been a favorite mod on spyders for ages, and one can be done pretty quickly for about $100 if you already have a reg. Basically any spyder with a new valve, some home mods (mostly drilling larger air pathways) and a spring kit can get that low no problem, though it does take some spring tuning. Also for some strange reason almost all spyders are able to run at a lower pressure with CO2 instead of HPA.
Drexel University Scenario Team
Sponsored by Valken
#20 User is offline   brycelarson
  • Show me the Data!
Posted 30 March 2009 - 06:26 PM
yeah, the zenith is at 250-300 psi, but what does the blitz run at? The Kaos is a HP gun - I sweetspotted mine to 650.
