TechPB Forum: Rate the Photo Above You (Read The Rules Before Posting) - TechPB Forum
  • 60 Pages +
#1 User is offline   XPB
Posted 08 October 2008 - 04:41 PM
Rules
1. No text posts.
2. ALL post must include a photo that YOU took. (only 1 photo per post)
3. ALL post must rate the previous photo on a 10 point scale. 10 = nearly perfect, 1 = lousy.
4. No retaliation ratings. So if you get a low rating on your shitty pick don't give the guy that rated it a bad one cause your mad.
5. Max image posting size is 800 pixels on the longest side.
6. When you see a post that ignores the rules, report it and ignore it. Rate the previous photo.
If you fail to follow these rules you will be warned. Repeat offenders may be banned.
This post has been edited by HKA: 24 August 2009 - 10:27 PM
#2 User is offline   XPB
Ill Start
#3 User is offline   chad
Posted 08 October 2008 - 04:46 PM
lol, you like that photo. 6/10 there is a lot going on and its hard to see what the actually subject is but still nice.
#4 User is offline   XPB
Posted 08 October 2008 - 04:48 PM
8/10
Nice lighting
#5 User is offline   android17ak47
Posted 08 October 2008 - 04:54 PM
8/10
Mine
#6 User is offline   XPB
Posted 08 October 2008 - 04:56 PM
3/10 Just a Pic of a gun.
#7 User is offline   chad
Posted 08 October 2008 - 04:59 PM
7/10
i like the the timing, but i dont like how the bunker isnt straight i makes the composition weird. i know its not your fault.
edit: its ambient light, to give it an eerie feel, since its Alcatraz.
#8 User is offline   XPB
Posted 08 October 2008 - 05:03 PM
8/10 Awesome Lighting!
#9 User is offline   Captain Hollywood
Posted 08 October 2008 - 07:11 PM
7.10 Great Lighting.
#10 User is offline   Big Red
Posted 08 October 2008 - 07:45 PM
8/10 Nice angle!
Y
oung Gunz Club,
#11 User is offline   XPB
Posted 08 October 2008 - 08:46 PM
6/10
Kinda Boring
#12 User is offline   chad
Posted 08 October 2008 - 09:07 PM
7/10 seems one stop under-exposed
#13 User is offline   ClearVision
Posted 08 October 2008 - 09:09 PM
7/10
Attached File  ion1.jpg (105.06K)
#14 User is offline   chad
Posted 08 October 2008 - 09:11 PM
3/10 what is it.
#15 User is offline   ClearVision
Posted 08 October 2008 - 09:23 PM
It was sunlight going through the trigger frame of my paintball gun click on it to make it bigger
7/10
#16 User is offline   chad
Posted 08 October 2008 - 09:26 PM
lol i did click it to make it bigger, i just couldnt tell. i got it like 3 seconds before you posted. anyway. 6/10 its under exposed and its just a regular playing with depth of field shot.
#17 User is offline   ClearVision
Posted 08 October 2008 - 09:35 PM
lol ok
8/10
Attached File  nus.jpg (265.79K)
#18 User is offline   XPB
Posted 08 October 2008 - 09:43 PM
5/10
#19 User is offline   chad
Posted 08 October 2008 - 09:59 PM
7/10 i give way to many 7's. it would be better it you used rule of thirds. and i think it would be much better if it was facing his back.
#20 User is offline   Captain Hollywood
Posted 08 October 2008 - 10:15 PM
7/10 :P, Great Shot
Ad I did for Colgate
  • 60 Pages +
