TechPB Forum: War's TM-15 project - TechPB Forum
  • 7 Pages +
War's TM-15 project A work in progress: now with box magazine!
#1 User is offline   Warwitch
  Posted 23 August 2009 - 09:12 AM
Hi everyone. Chace from AO asked me to post up a rundown of my latest project here. Ill try to abbreviate/condense a couple different threads to simplify things. Ill be doing an in depth, ongoing review but we will save that for another thread.
I had been kicking around several ideas to make myself a more user friendly woodsball marker for myself. My requirements were very basic. 1: I wanted a side deeding body. 2: Simple design 3: Easy maintenance. After kicking around several cantidates I settled on one of BT's new Mini based TM-15's.
Here is what I started with:
Shown with Sanchez Machine SM1 and w/o flip up sights/hopper adapter.
I knew form the start that I wanted to shorten the foreguard. So I took the front down to the second internal body baffle. I used a fine metal hacksaw and mitre box for the rough cuts. Then I bolted the clamshells together and dressed the end nice and square/smooth with a flat file. The detail areas around the picatinny I did with a needle file. A quick buff with some 400 grit wet sand and it read to paint.
I used Krylon Fusion CAMO paint. Their camo stuff is really tough and fairly flexible. Much more so than their regular Fusion colors. It also dries really flat. I did very little body prep. A light scuffing with 400 grit and a wipe down with paint thinner (mineral spirits.) Everything got several light coats in either tan, olive drab or dark brown. I painted the rails first. Then masked them off an did the rest of the body. I finished off the detail on the fire modes with some Testors model paint and a toothpick. I used a flat stiff bristle brush for the TM lettering.
So then it was on to the box magazine. This was the reason I wanted a side feeding marker to start with. In an age of force fed hoppers a top loading marker is just dumb. I got the inspiration from Oily's M249 box magazine. Props to him for being the pioneer. I decided to use an Airsoft mag since it would require little modding to fit the mag well on the TM-15. The steel mag took some Dremel work as the retaining slot was off a bit. The interior also too copious amounts of Dremeling to remove all the Airsoft guts and dividers. The plastic its made if is unbelievably tough. I used a couple of 3/4" copper elbows for directing the paint from the chopped Reloader B and into the marker. I used a cut 140 round pod for the feed port. This will eventually be widened at the neck with a speed feed. Epoxy was used for all the bonding work. The last thing to do was mount the board. Having access to it was an issue. So I decided to cut the back off of the Reloader B shell and make an external mount. It plugs in via slot in the back of the mag. Test firing with 6 AA's keeps up with the 10 bps full-auto setting on the TM-15.
So without further ado here is the (semi)finished result:
Here is a pic of the mag internals I took during mock up:
#2 User is offline   Stev02112
  • My name is Stev, not Steve.
Posted 23 August 2009 - 09:16 AM
Really fucking cool. Drum mags on small guns FTW!
#3 User is offline   Chace365
  • Slurm!
Posted 23 August 2009 - 10:16 AM
Hey Warwitch!
Thank you so much for doing this!
Many members were interested in this.
Looks cleaner than the one over on UMS, eh?
B)
Want to be an ASS-HAT?
Go ahead and put a big FIRST as a reply to someones question.
Modder's Guild- Where custom is customary.
#4 User is offline   PrometheanFlame
  • Nein, you tiny demons! NEIN!!
Posted 23 August 2009 - 11:49 AM
Warwitch, Deadpool was showing off some of your work and had me drooling all over the place. I hope you don't mind if I copy your general design for a project of my own? It'll basically be the same thing, except mounted on a rail instead of in a mag-well.
If you're interested in making a little coin, I'd be happy to pay you to do it, though...
Grammar Nazi Fuhrer : LL3 Soulja : Eleven Percenter
#5 User is offline   Warwitch
Posted 23 August 2009 - 11:53 AM
Hey go nuts man! Its actually Oily's original idea, I got it from him. And though I appreciate the offer I doubt Ill be doing another one any time soon. I have a couple more mods in mind for this and the wife only allows me so much tool time. :P
#6 User is offline   Đάłŧŏ&#
Posted 23 August 2009 - 12:02 PM
I've been wanting to make a box mag for my A-5 for a while, I just need the cash. Also, what hose did you use to connect the boxmag and marker? and where can I pick some up?
#7 User is offline   Warwitch
Posted 23 August 2009 - 12:05 PM
Thats AGD Warp feed hose. You can get it at Pro Team Products: <<< Pro Warp feed hose >>>
The stuff is much better than the Q-loader type hose. The Warp hose has a spiral wire that keeps the hose from getting crushed if it takes a hit. It flows paint with much less resistance too.
#8 User is offline   PrometheanFlame
Posted 23 August 2009 - 12:12 PM
That's alright, I knew it was a longshot anyways. And for some reason, I thought you were a woman. :blink: Awkwaaaarrrrd...
Very good to know. I had been planning to use Warp hose, and was concerned about it being able to take a hit.
#9 User is offline   Đάłŧŏ&#
Posted 23 August 2009 - 12:14 PM
So can you explain a little more in-depth about the boxmag? (specifically the reloader b part) did you have to hack the bottom peice of the hopper off? or? :blink: (yeah, im confizzled)
This post has been edited by Đάłŧŏŋ: 23 August 2009 - 12:14 PM
#10 User is offline   U83R 1337
  • There's no kill like overkill.
  • Group: Banned
Posted 23 August 2009 - 12:17 PM
Do you foresee the mag catch not being able to hold the whole weight of the mag?
This post has been edited by U83R 1337: 23 August 2009 - 12:17 PM
Canadian Baller
Metalhead
HeyHeyHey, on 28 June 2010 - 08:02 PM, said:
#11 User is offline   Chace365
  • Slurm!
Posted 23 August 2009 - 12:19 PM
He already said over on AO that he put some through it alright.
I think. :blink:
#12 User is offline   Warwitch
Posted 23 August 2009 - 12:32 PM
The only thing I did was cut the down spout off the raceway and add the copper elbow. I cut the board mount section off the back of the Reloader shells so I could make a mount. I didnt want the hopper board inside the mag. Its much easier to turn on/off and makes more room inside for paint.
It holds everything very securely when fully loaded. The system holds about 175 rounds. Which is ideal for me. Im not a paint slinger. Almost always shoot semi only and I rarely carry more than two pods on the field. My goal for the mag was being able to fit 140 so I could use full size pods. I have a plan to move the batteries outside too so that should add another 50 rounds or so. :)
Edit: I have run a couple hoppers through the system with no problems. But it will be a bit before I can get more air for further testing and vid.
This post has been edited by Warwitch: 23 August 2009 - 12:34 PM
#13 User is offline   Đάłŧŏ&#
Posted 23 August 2009 - 12:36 PM
If I was you, I would remove the magwell and put it on some picatinny rails. Then you would be able to hold another like..... 50+ paintballs.
#14 User is offline   Chace365
  • Slurm!
Posted 23 August 2009 - 12:40 PM
Dude. The magwell is what's holding the boxmag on.
#15 User is offline   Đάłŧŏ&#
Posted 23 August 2009 - 12:59 PM
Did I not say mount it on some picatinny rails?
#16 User is offline   PrometheanFlame
Posted 23 August 2009 - 01:58 PM
That's what I'm planning on doing. Just need to find the appropriate rail hardware to secure the plastic.
Something like this,
but maybe a little cheaper than fifty freakin' bucks. I'm trying to keep my total project budget under a hundred bucks. The airsoft ammo box will cost me around $30, and if I can grab a Reloader B used that'll probably be another $40 or so.
This post has been edited by PrometheanFlame: 23 August 2009 - 02:04 PM
#17 User is offline   Warwitch
Posted 23 August 2009 - 02:04 PM
Moving it forward wouldnt give me the clearance to reach around the mag.
#18 User is offline   PrometheanFlame
Posted 23 August 2009 - 02:06 PM
I think he meant cutting the mag-well off the gun itself and extending the foregrip rails back where it used to be. The loader would then mount there.
#19 User is offline   spankopotomous=paintball
Posted 23 August 2009 - 02:07 PM
OMG that is one of the best looking mil-sim guns I have ever seen :rolleyes:
AWESOME JOB
Spanko's random junk sale!
#20 User is offline   Gibbs
  • reppin the 613
Posted 23 August 2009 - 02:09 PM
wow, that looks so badass
  • 7 Pages +
