MacDev's lightest marker yetThe all new MacDev Clone has liquid 3D milling that is reminiscent of the original Droid design, however it has been updated with smoother lines and tighter shaping around internal components. This results in a much lighter and sleeker looking marker, the end result being 13% lighter than the 2007 model Droid.
The new Clone weighs in at only 880g/1.94lbs with 14" barrel and battery.
A new step forward in spool valve technology
In 2007 MacDev released the Droid and set a new standard by delivering a spool valve marker that was both fast and efficient. Now the MacDev Clone takes those features one step further. The Clone drivetrain features a massive 425% increase in valve flow, and the use of new size o-rings to reduce friction drag by more than 60%. The new drivetrain is also 12% shorter, making it lighter and also shortening flow paths for more efficient air delivery.
As if that wasn't enough, the drivetrain is removable and rebuildable without the use of tools - simply unscrew the back cap and the entire drivetrain comes out in one piece.
RX2 Gladiator: More stable & reliable than everPowering the Clone is the next generation RX2 Gladiator regulator. The RX2 boasts the highest flow, and fastest recharge available to date. It also has easier maintenance with the new spring system replacing the old stack.
In addition to the filter technology pioneered in the Cyborg RX, the RX2 Gladiator now has internal dirt avoidance countermeasures by means of positioning the piston seat in a way that will keep debris away from delicate parts. This is the only regulator that protects itself so that debris cannot damage the internals, causing unsafe pressure levels inside your marker.
RX Frame
The Clone builds on the success of the Cyborg RX by offering the same thin grip frame, molded grips and rear button pad. Included is the RX board with OLED, USB port and a variety of modes, user-programmable profiles and more.
The trigger pivot point has been moved forward to make it easier to shoot fast, with a new trigger with improved ergonomic shape. The Clone's grip frame is still compatible with Cyborg RX triggers also.
New clamping feedneckThe Clone uses the new feedneck system introduced with the Cyborg RX. The new Clone feedneck features an improved lever and a low profile design to keep your hopper lower and allow you to play tighter.
Shift Barrel
The Clone comes with MacDev's newest barrel, the Shift. The Shift is incredibly light, quiet and has an innovative insert system which connects the insert to both the back and front pieces ensuring it will always stay in place.
The Clone comes with a .691 insert. An upgrade kit with a full set of Shift inserts will be available so you can easily match your barrel to your paint size.
The most efficient spool valve markerThe MacDev Droid was the first spool valve gun to bring efficiency to a new level, being the most efficient spool valve gun ever since its release. The Clone continues the trend of being the most efficient spool valve marker offering 1,700+ shots from a 68/45 tank @ 290fps.
Shown left to right (red, aqua, silver, black)
This post has been edited by ZamBaller: 09 December 2009 - 09:17 AM
