so i went to the paintball store and talked to them and they recomend the bob long protege. Heres why: i live in bay area so im close to the bob long factory. its made in the USA. the shop is a bob long repair shop. and they can get the parts and gun in about a day. life time warntey.
if you like the etek then try to change my mind if you like the bob long please give me more reasons to buy it. thanks
etek 3 am vs. bob long protege please help
#1
Posted 02 January 2010 - 12:25 PM
#2
Posted 02 January 2010 - 12:38 PM
There's no reason for you to get the etek 3 over the protege in your case. You live near the BL factory and you have a shop that is certified to repair bl markers so warranty issues and repair issues should not be a concern for you. You'll have quick turn around and good feedback. Even IF the etek 3 is considered "better" I'd always go for something local because it'll be a much less painful experience if something goes wrong.
#3
Posted 02 January 2010 - 12:43 PM
proteges are better
1: bob long guns are made for semi automatic:
the pivot point is behind the trigger so it makes it feel lighter and allows the trigger to be walked easier.
2: consistancy/effitiancy
not once has my gun gone down on me during a game, it never jams, rarely any breaks at all! and you can play an entire game shooting as much paint as you want with even a 45/30 and youll never have to worry about running out of air
3: battery life:
amazing!! this gun can shoot soo many cases with only one nine volt.
4: bob long has the best tech/costumer support! its amazing!
i have shot both guns and i like the feel of the bob long in nmy hands better, you have tons of room to move your fingers inside the trigger guard, and its overal jsut a great gun
and also these guns are soooo easy to fix and maintain, you can take the entire thing apart no problem
3: battery life:
Carp Coalition - MXL
MARKED PAINTBALL FTW!!!!
#4
Posted 02 January 2010 - 12:44 PM
ok ya with a 68/45 the owner got around a case through it before refilling it. and i only shoot about a case a day
#5
Posted 02 January 2010 - 01:56 PM
if you decide to buy a protege and want a cheap one send me a pm
#6
Posted 02 January 2010 - 02:00 PM
in your case definitely get the protege, life time warranty and repair services. not bad
It's not the size of the dog in the fight, it's the size of the fight in the dog.
Empire Prophecy v2 for sale: http://www.techpb.co...howtopic=140892
#7
Posted 02 January 2010 - 04:23 PM
what would you guys suggest if he did not live near a bob long shop or approved bob long tech centre what you you approve then? just wondering because im in the same boat wondering which one is better and i live in the uk and dont know of any boblong shops near me
G6R
XSV SL74
Dynasty Shocker
Setup = XSV SL74 or G6R, DXS 1.1l, Dye Rotor
XSV SL74
Dynasty Shocker
#8
Posted 02 January 2010 - 05:48 PM
Planet eclipse is located in the UK so Id get the etek 3
#9
Posted 02 January 2010 - 07:54 PM
nickd im only buying a new one
