TechPB Forum: T8.1 mag compatability? - TechPB Forum
T8.1 mag compatability? Do T8.1 mags work with a t9?
#1 User is offline   slayermaster
Posted 05 January 2010 - 01:43 PM
Okay here is my problem, I was just looking at the t8.1 mags and apparantly they have a quick seal that takes away the need to use an allen key, i've been using only two mags at this point, and the second has been my friends because he doesn't use it. So I'm wondering if the new T8.1 mags will work with my T9?
-halpz
#2 User is offline   Deadpool
  • Knock knock. I have a delivery of pain, will you sign?
Posted 05 January 2010 - 03:12 PM
-halpz
I believe that is a yes (someone please correct me, if that is not the case). The original T8s can use the new FS or T8.1 mags but the T8.1 cannot use the old mags. I believe this is the same with the T9 as well.
#3 User is offline   monkeyman
Posted 16 July 2010 - 02:50 PM
i would beleave so i dont see why not
MARYLAND BALLERS FTW
#4 User is offline   DP FUSION
  • ** Speed Kills**
Posted 21 August 2010 - 12:30 PM
yes they do
