TechPB Forum: delta elite help - TechPB Forum
delta elite help
#1 User is offline   shobros
  Posted 03 December 2008 - 09:40 PM
ok so im in virginia and i tech for my bro in louisiana. his problem: first the ant shock oring at the very back by the stock he lost.(the o-ring that just falls out when you take it appart. 2. his bolt will not cock all the way back and stay hooked on the sear(if this is the pin like item that holds the bold; that is on gripframe). are they related? and this is all with no air in the gun. he pulls back the bolt, lets go, and it goes right back to the fore position. does someone know what i am talking about? Thanks ya'll.
-Shobros
"if you think its too good to be true... it probably is" "what doesn't destroy you can only make you stronger." "nothing ventured, nothing gained" "when life gives you lemmons... make orange juice and watch as the world wonders how you did it."
QUOTE (antifat @ Jul 13 2009, 12:32 AM) <{POST_SNAPBACK}>
If your sad, watch porn.
Seriously, if your still sad while watching porn, you've already failed basic instinct priority #1.
#2 User is offline   karolinen
Posted 29 January 2009 - 04:02 PM
the oring in the back you can get if you buy the sparepartkit it have lots of stuff in it it can be related guess you can get a oring if you can find a good hardwarestore guess its calld that writhing from sweden get a hold of the sparepartkit and test it.
hope it works Karolinen
