TechPB Forum: Tippman sniper - TechPB Forum
Tippman sniper
#1 User is offline   Pinkcow17
  • Group: Banned
Posted 27 April 2010 - 05:35 PM
so i have decided to build a sniper for woodsball. i chose tippman because of the flatline barrel,feedneck on the side of the gun and the rails.
Which gun should i use?
which barrel?
how big are the rails on tippmans? 12mm,20mm and 3/8"(whatever that is in mm)?
what kind of scope?
#2 User is offline   bigfootpm
  • Not A Newbie Member
Posted 27 April 2010 - 06:04 PM
You cant make a sniper as a thought of being able to shoot lonr range but you could sneak around and get them by surprise. But if you are going to tey get a apex barrel and you can relly use scopes becuase it would be hard to see through with you mask on and paintballs are to unpredictable.
#3 User is offline   Pinkcow17
  • Group: Banned
Posted 27 April 2010 - 06:11 PM
i know a sniper wouldnt shoot further i just want to make on for the fun of it and so i can get a "one shot one kill?" instead of spraying 2 balls hoping for hit. the reason i want a sniper is mainly just for hell of having a sniper :) but i want to make one that will actually work as a sniper. Would it help if i got first strike rounds?
#4 User is offline   bigfootpm
Posted 27 April 2010 - 06:14 PM
First strikes rounds would work but you would have to get a special gun and then a converson kit. A apex would give you more range and you dont have to put $8 for a tube of paintballs.
#5 User is offline   PacosTacos88
  • hetero-flexible
Posted 27 April 2010 - 06:16 PM
Any marker can be a sniper. No marker is really more accurate than any other.
Options you have:
1) Quiet sniper - Using a fast and quiet marker to take the enemy team by surprise.
2) Long range - Use either an A5 Flatline (98 custom sucks), or any marker with an Apex tip. Problem? Long range paintballs don't usually break on target, so spray and pray comes into effect again.
#6 User is offline   bigfootpm
Posted 27 April 2010 - 06:17 PM
If you want to do the one shot one kill thing get a pump
#7 User is offline   Pinkcow17
  • Group: Banned
Posted 27 April 2010 - 06:22 PM
would this be a good setup?
a-5
flatline(is there only 1 kind of flatline barrel)
invert halo too(i have one)
stock(doesnt really matter which one?)
scope: http://cgi.ebay.com/...9#ht_9276wt_991 ???
#8 User is offline   PacosTacos88
  • hetero-flexible
Posted 27 April 2010 - 06:23 PM
The A5 has it's own air powered hopper system. Lol, night vision?
#9 User is offline   Pinkcow17
  • Group: Banned
Posted 27 April 2010 - 06:35 PM
yeah :P its only 12,000$
#10 User is offline   Gregoro
Posted 27 April 2010 - 07:17 PM
It's called a cyclone feed, and it comes with the marker. Why would it be 12,000$?
I say get a pump!
#11 User is offline   Pinkcow17
  • Group: Banned
Posted 27 April 2010 - 07:20 PM
check the link
#12 User is offline   findecano1
Posted 27 April 2010 - 07:56 PM
I say get a pump!
Its the NVG that is $12k..... :rolleyes:
Oooppss... NV scope not goggle
This post has been edited by findecano1: 27 April 2010 - 07:59 PM
Noob Baller
VForce Grill Tan
Macdev Droid 08 vampire
Empire Prophecy & Halo B
70/4500 Ninja & 68/4500 CP
#13 User is offline   PBDemon
  • *Click to Change
Posted 27 April 2010 - 09:00 PM
98 pro(the one with cyclone). less bulky than a5 and x7. go with cp tactical .679 with apex tip. a standard acog scope would be good. the gun wouldnt be accurate enough for pinpoint accuracy.
or go with a rap4
http://www.rap4.com/...r-paintball-gun
600.00
real magazine fed.
sexy
what more can you want is a mil sim gun
Feedback: Ebay TechPB +10/0/-0__________________Etek3, Nokio, Ninja 68/45
Ccambell95-I was putting my fill nipple cover on my face and I looked in my mirror to see tiny round hickeys all over and I cant get em off
#14 User is offline   Woodsballer117
  • Xtreme Member
Posted 27 April 2010 - 09:16 PM
I'm going to be honest with you about this that in my personal opinion the only true sniper in paintball is a Tiberous Arms gun(T9,T8,T4) with First Strike rounds since the rounds go so far, and they have an effiect loading system for it.
#15 User is offline   asmodia255
  • AGG-modia the Agg!
  • Group: Retired Staff
Posted 27 April 2010 - 09:23 PM
Sniping in paintball is less about accuracy and more about element of surprise.
#16 User is offline   pbduck
  • visible impact
Posted 27 April 2010 - 09:43 PM
get a 98 or A5. get a raised sight rail with the a red dot scope w/ a flatline
#17 User is offline   findecano1
Posted 27 April 2010 - 09:47 PM
+1
+0.5 as FS rounds can be quite incredible
Noob Baller
VForce Grill Tan
#18 User is offline   bigballa
  • Who's Your Papa?!?
  • Group: Banned
Posted 27 April 2010 - 09:51 PM
I think a 98c is the best. Just put a new barrel, stock and a walmart red dot and call it good.
#19 User is offline   Mantown Mayor
  • Veni, Vidi, Vici
Posted 27 April 2010 - 10:08 PM
You can get a pretty nice set of night vision goggles for $300-400.
They won't be military grade, but you can see in the dark with them.
As for the gun, if you REALLY want to shoot as far as possible, get a T9 that's First Strike ready.
Check this out:
http://www.ansgear.c...rifleranger.htm
BST Feedback
Pinokio 4 Life
#20 User is offline   asmodia255
Posted 28 April 2010 - 01:25 AM
Seriously instead of wasting your money on "upgrades" for a Tippmann they in all honesty just weigh it down, save your money and get a ghillie suit and practice creeping and sneaking around. Don't buy a scope or red dot because they are completely useless in paintball (sans first strike). If you really want that one shot one kill from a distance you need to go with a T9. The apex and flatline will not give you the accuracy you're looking for.
Ambush > Sniping any day.
