i also polish internals on tippmanns to make then shoot smoother, and i micro polish bolts for any gun. i do soldering work on anything for a gun
you pay shipping to and from my house and pp me $30 ($15 of that covers shipping back to you) and this is what i'll do.
complete teardown of all the regs, housings for everything, clean absolutely everything and relube it for you, once i'm done i will put some air through the gun and make sure i fixed whatever problem you were having.
i will leave the regs the same pressure as when i got your gun and i wont mess with any settings on the board. unless you give me an extra $5 to do that for you, and i will put a pod of paint through your gun to make sure it shoots well and i will set your velocity at 280fps or whatever you want me to set it at.
i ship usps flat rate boxes and i insure them and add confirmation, depending on how much your gun is worth insurance might be more or less, $200 and under is $2.75 and $200 and over is $4.75. shipping takes 2-3 days usually, its very fast.
so say you have an (enter any gun here) and its having horrible shootdown and chopping and its all dirty and not consistent, i'll give you my address, you ship your gun to me and pay pal me $30 once i get your gun (2-5 days depending on how you shipped) i will do a complete teardown when i get it and completely clean everything for you, put it back together and air it up and make sure it shoots(dry fires). but if you paypal me $35(extra$5) i will also set your regs to where they need to be at and chrono your gun and make sure your board settings are what they should be. then i will package your gun up, and ship it back to you and then pm you with the tracking info. and its a done deal.
orings and lube are all part of the deal, i dont charge extra no matter how many you need, if i see an oring that needs replacing i will replace it and lube is not an issue you dont have to pay extra for that either.
if your gun needs a part, say a broken noid or board or something, you will either pp me the money needed for the part or you can just order it and have it shipped to my house, if i break anything at all in your gun while fixing it, that money comes completely out of my pocket and i will replace the part.
This post has been edited by firebirdjimbo: 12 June 2012 - 12:37 PM
