Hopper and HPA tank for Begginers
10 replies to this topic
#1 luvstospooj646
  • 46 posts
Posted 05 November 2010 - 10:06 PM
What kind of hoppers and tanks would be good for a starting speedball player?
Gog G-1 Blackheart
62/3000 Guerilla
Invert Too
#2 xFataLxMerkiNx
  • 351 posts
Posted 05 November 2010 - 10:12 PM
What kind of gun do you have/want?
1. Halo B V35 http://www.ansgear.c...35wripclear.htm
2. PMI 62/3000 http://www.ansgear.c...mialu623000.htm
hope this helps :)
DP G4, Ninja 50/4500, Rotor
Put this in your sig if you have played 2 man ten ball with ninja dave himself :)
#3 PaintballingTings
    Who says Speedball and Woodsball can't be friends? ;)
  • 305 posts
Posted 05 November 2010 - 10:45 PM
Invert Too, and Invest in a carbon fibre ninja or ga tank ..... It will last a long time and you won't need to upgrade.
Getting a steely will eventually want you to get a better tank., and youll upgrade to a carbon fibre.
But you can't get anything better than a carbon fibre tank, so there is no need to upgrade later .!
"You gas up the marker, put on the gloves, strap on the mask, and walk onto the field with your head held high, and it doesn't matter that you failed a test, didn't get the girl, or that you got a ticket on the way there.Your world is right for the next couple of hours." ~SOCIAL PAINTBALL
#4 ThunderLights
    Turbocharged Member
  • 9,202 posts
Posted 06 November 2010 - 07:19 AM
loader: invert too - 70 bucks or a super loader if you have the budget
tank: 48/3000 for the more budget guys... umm its better if u get a carbon fiber 4500psi tank because there lighter and hold more air. a 68/4500 will be the right size if your a bit older/taller/bigger, its the most common size. the 50/4500 or the booby tank is for the little guys who play. and the 45/4500 is 1/2 and inch shorter than the 68/4500 and i believe its lighter. its all up to your size and budget. the are also the 72/3000, 90/4500, 13/1300 but no one really uses them that much. the steely tanks (3000psi) are retailed right around the $50 mark and the carbon fiber (4500) are around the $150 mark. I've seen them go up from that a little but i dont know why. i personally like ninja tanks cuz there the best but GA and Crossfire are alright. (i think mike uses a 68/4500 ninja bottle with a crossfire reg)
#5 MrMetal1091
  • 892 posts
Posted 06 November 2010 - 09:45 AM
i agree from experience of buying a steel tank that it is way better to just front the money for a carbon fiber tank there lighter, and hold much more air
Playground Resurrection #11
On Point Paintball Supply
The Playground
Captain Oring
#6 Jeremy!
    I would kill a man for a rotor
  • 118 posts
Posted 06 November 2010 - 10:24 AM
I love my 48/3000 steely tank, but if you have the money, go for the best one you can get. Invert Too's are good ^_^
I pay to mow face. I don't plan to get shot.
#7 Freshtastic
  • 245 posts
Posted 06 November 2010 - 09:38 PM
Loader: Invert too, at 70$, its a fucking steal if i've ever seen it. It's a great loader.
Tank: CP 68/4500, or ninja 68/4500. Both companies are great for their tanks, you could get smaller ones depending on your size, but DONT GET A STEEL TANK. It's better if you just wait and get a carbon fiber one.
The King of you monkeys
Proudly From the Canadialand
#8 dannyboy768
  • 2,028 posts
Posted 07 November 2010 - 10:39 AM
It depends on your budget. If your on a budget then get an Invert Halo Too and a Ninja 48CI Steelie, if not get an Empire Prophecy and Ninja 68CI Carbon Fiber. Both combos are REALLY good!!!
DIRT CHEAP CF Tanks in Hydro!
#9 PiLLoWPaNTzZ123
    "I didn't break it, I fixed it wrong"
  • 331 posts
Posted 07 November 2010 - 12:16 PM
Definitely a Too for you if your on a budget, if not i'd say get a Prophecy/Rotor/Pinokio,
Budget tank- 48ci Steelie, if you have the money get a 68/4500 from Ninja
#10 TheGuy
    I like lamp
  • 13,799 posts
Posted 07 November 2010 - 12:18 PM
Get good stuff first so you arent trying to sell it and then buy better you will just end up spending more.
hopper- invert too
tank- ninja 68/4500
#11 pbnsucks
  • 5 posts
Posted 09 November 2010 - 05:07 PM
Invert too
tank: crossfire 45/4500 low pressure tank
