Need help Proto rail 2011
21 replies to this topic
#1 Not a fanboy...
Not a fanboy...
  • 48 posts
Posted 01 December 2010 - 11:43 PM
Ok so I have the strangest problem ever with my new pmr 2011 (not the reflex)
1. I gas up the gun turn the gun on and everything works fine for about the first 20 shots the eyes are working properly along with no leaking that I can hear or feel.
2. The green light starts blinking green indicating the eyes are dirty so I turn the eyes off (cleaning the eye pipe didn't help)
3. The gun makes like a 1/4 shot kind of noise and balls start falling out of the barrel the solenoid is still clicking
4. It does this every time and I can't seem to pin down why the gun isn't leaking it gets off 20-50 (200-400psi used)shots fine no issues than its just mayhem please help. Someone did say it may be that the tank is not fully screwed in and moving the mount for the tank back a bit would help haven't tried it yet. I should also add that I have shot 1000 paintballs the first day worked fine, then this outing the problems started so I don't believe the regulator is broken in.
I'm going to take it into my local field with a tech there and see if we can solve the problems otherwise I'm sending it back to dye/proto for warranty.
One more thing again the gun when it shoots those 20-50 shots on the chrono they are at 290fps +or- 5fps
Thanks, Colin
Edited by Not a fanboy..., 02 December 2010 - 08:41 PM.
#2 Fas0ne
Fas0ne
    I'm Rick James BITCH
  • 163 posts
Posted 02 December 2010 - 12:23 AM
Change the battery. Always use a high grade battery like duracell or energizer.
#3 Plattypus
Plattypus
  • 8,570 posts
Posted 02 December 2010 - 12:36 AM
This or change your dwell.
Although, I don't know if the dwell is adjustable in the Rail.
My Feedback +3/0/0
#4 Not a fanboy...
Not a fanboy...
  • 48 posts
Posted 02 December 2010 - 12:41 AM
Ok im putting up a video guys so you can actually see the problem :D Also are the stock proto batteries really that bad lol?
#5 Plattypus
Plattypus
  • 8,570 posts
Posted 02 December 2010 - 12:42 AM
Yes.
Go buy Duracell or Energizer plz. :)
My Feedback +3/0/0
#6 Not a fanboy...
Not a fanboy...
  • 48 posts
Posted 02 December 2010 - 01:56 AM
Video
#7 Senior SL8R
Senior SL8R
    World Domination.
  • 3,917 posts
Posted 02 December 2010 - 02:09 AM
Ahh, I See the problem . . . You've bought a 2011 PMR . . .
- Crew 343 - D5 -
#8 Not a fanboy...
Not a fanboy...
  • 48 posts
Posted 02 December 2010 - 02:11 AM
lol yes thats.....very helpfull
#9 Smokey MacPot
Smokey MacPot
  • 589 posts
Posted 02 December 2010 - 12:49 PM
There are TWO 11 Pmr's in Edmonton?!?!?!?!
Did you turn the anti stick off by chance?
Your bolt sticking ?
Worse comes to worse Derrik(at prevail) will get it working just fine.
Edited by Smokey MacPot, 02 December 2010 - 12:50 PM.
#10 Fas0ne
Fas0ne
  • 163 posts
Posted 02 December 2010 - 01:52 PM
Doesnt look like a stick, put a duracell in it, if this doesnt work take a look at the reg.
#11 Not a fanboy...
Not a fanboy...
  • 48 posts
Posted 02 December 2010 - 02:29 PM
I am going to buy some new energizers today, and I'm thinking that will fix the problems from my knowledge of batteries, but if it doesn't paintball action games said bring it in to the pro shop and if they can't figure it out they will send it back to dye/proto I'll maybe talk to Derrik as well. Also haven't adjusted the dwell I can and the anti bolt stick is on. Thanks guys
Edited by Not a fanboy..., 02 December 2010 - 02:33 PM.
#12 sticktodrum
sticktodrum
  • 11,913 posts
Posted 02 December 2010 - 03:19 PM
The blinking actually is for eye malfunction, and it says (I believe) in the manual "dirty". It is most likely the battery as was said. Can you see if the tank is not sufficiently screwed in?
#13 Not a fanboy...
Not a fanboy...
  • 48 posts
Posted 02 December 2010 - 03:33 PM
I thought the tank was not screwed in all the way as well so what I did was I took the airport mounting area and as the manual said i moved it back so I could clearly see all the treads and it is indeed seated properly. And yes you are right it does say "eye failure, eye is blocked or dirty" tested the battery with my volt meter and it as well said not under load a voltage of 7.85 so ya lol
Edited by Not a fanboy..., 02 December 2010 - 03:36 PM.
#14 sticktodrum
sticktodrum
  • 11,913 posts
Posted 02 December 2010 - 05:19 PM
So did you change the battery?
#15 Not a fanboy...
Not a fanboy...
  • 48 posts
Posted 02 December 2010 - 07:18 PM
Ok got a battery and guess what it works fine lol thanks guy.
#16 sticktodrum
sticktodrum
  • 11,913 posts
Posted 02 December 2010 - 07:40 PM
I knew it!;) Voltage tester must be broken, or it wasn't an issue of voltage. I hope you got a multi-pack of batteries.
#17 Not a fanboy...
Not a fanboy...
  • 48 posts
Posted 02 December 2010 - 08:38 PM
everytime i have used a 9v if it drops below 8.5v it doesn't work in anything but like a calculator.
#18 DYE NT
DYE NT
  • 2 posts
Posted 23 February 2011 - 01:57 AM
lol i was checking youtube and saw your video and now im looking at your post and u had the same problem and then u posted your video ont his blog. its wierd cuase i saw your video before the blog hehe
#19 dyeguy23
dyeguy23
  • 8 posts
Posted 02 October 2011 - 01:54 PM
wtf i have the same problem how can we fix it
#20 stuff21397
stuff21397
  • 55 posts
Posted 16 October 2012 - 07:59 PM
if you unscrew the fitting on the asa were the braided hose is there is a nut in there that you can screw in to allow ore air flow to the gun. Try that but I don't know why Dye did that but good luck either way
#21 Kingmeco242
Kingmeco242
  • 1 posts
Posted 23 February 2013 - 11:50 PM
I Need Help!!!
I Have A 2011 dye Proto Rail...It Worked Find The First time I used it but now im about to play i cut my hopper on and my gun is on as well it goes from red to green to say a ball is loaded..i would shoot couple shots in the game and then it would just turn red but my hopper is still on i never turn it off! so in order for me to play i would have to play with eyes off!(not cool Chops Balls) i lube up the bolt nothing change put a new battery in nothing changes can someone help me?
#22 Anjin-san
Anjin-san
  • 35 posts
Posted 24 February 2013 - 10:21 PM
Change the battery and be sure to use a good quality one like Duracell or Energizer. When the battery starts to get weak most markers will start doing screwy things.
