Dangerous power G4 Trigger not coming back to regular position
5 replies to this topic
#1 PAINTBALL RULES!
PAINTBALL RULES!
  • 21 posts
Posted 28 December 2010 - 09:50 PM
Hello Techpb,
I just got a G4 for christmas and i just shot four pods through it and the trigger sometimes doesnt comeback to its regular position im not sure if this is bolt stick or something is wrong with the gun. Please help.
happy holidays,
paintball rules
#2 Rob14
Rob14
  • 15 posts
Posted 04 January 2011 - 12:25 PM
take the grip frame off and check all the magnets?(My G3 IQ has springs) and make sure you don't have any paint or debris in there. then take the trigger out of the frame and clean and re-lube everything. try adjusting your trigger.
DP G3 IQ, Virtue eyes, Stiffi MF 14", Rotor, 48/3000 steel, Custom grips
#3 Connor R
Connor R
  • 1 posts
Posted 08 January 2011 - 06:23 PM
I have the same problem. It came right out of the box have not played with it at all and I can't figure out what it was. Unless the trigger magnet was bad.
#4 Kingwood-Team Foxtrot
  • 5 posts
Posted 10 April 2011 - 07:19 PM
I have the same issue. Just started. It worked fine for the first 2-3 cases, then it just started sticking. No debris, not dirty at all, and I never messed with the trigger adjustments.
#5 Reality
Reality
  • 490 posts
Posted 10 April 2011 - 08:18 PM
Check the trigger adjustment screws and the magnet screw?
Axe
V2 Prophecy
70/4500 UL Ninja
#6 Kingwood-Team Foxtrot
  • 5 posts
Posted 11 April 2011 - 11:23 AM
Here's the response I got from DP.
Hello,
You will need to adjust the set screws both on the trigger and the body that adjust the travel and return of the trigger. Also you can check to make sure the Silver pin is not too tight as it can cause the trigger to have difficulty traveling.
Service Department
Strength, Power, & Dexterity
Dangerous Power Engineering
Tel: (626) 369-7800
Fax: (626) 369-7843
Dangerous Power
I haven't tried it yet to see if that fixes the issue but maybe it really is that simple!
