G3 PROBLEM!!!!!!!!!!!!!!!!!!!!!!!!!
9 replies to this topic
#1 lechoochpumpballer
lechoochpumpballer
    Pumper
  • 467 posts
Posted 30 September 2008 - 12:07 PM
The g3 needs an lpr because me and a bunch of other owners have blown their solonoids i have sold mine for a pump bot still!!!!!!!!!!!!!!!!!1 :angry:
Cocker Owners Club #22
WE ARE ONLY AS GOOD AS OUR LOVE FOR THE SPORT
Proud to be a closed bolt baller!#4@#
Pump players UNITE
Why Throw An Ion When YOU Can Sell it for 60$ ???
#2 Yoda
Yoda
  • 425 posts
Posted 30 September 2008 - 02:59 PM
If you blow your noid, more than once (could be faulty from factory) then you really need to use more caution when adjusting the marker.
Images used in signatures are to be less than Width of 600px, and height of 160px. Only ONE image is allowed in the signature, and it must be 30k or less. Only 5 lines of text are allowed. No text larger then size 2 is allowed in the signature.
#3 ballaXscott
ballaXscott
  • 5 posts
Posted 01 October 2008 - 07:52 PM
are you sure you blew your noid.. because dp noids are supposed to be very resilient.. maybe your regulator piston is busted?
#4 kooky47
kooky47
    No, Id win, look it up
  • 337 posts
Posted 01 October 2008 - 08:00 PM
Welll what was happening? Do you know it was the noid or are you just guessing. I don't see how you AND a bunch of other owners blew the solenoid if it wasn't user error. If you did blow the noid (and you know it wasn't your fault) you could've just got a replacement from DP
MY Sexy Ocean Rev-i, For Sale CHEAP
Maximum Paintball
Store Field
#5 lechoochpumpballer
lechoochpumpballer
    Pumper
  • 467 posts
Posted 01 October 2008 - 08:07 PM
i know it was my noid because when i aired it up all the air came blowing out of the bolt and my shop told me it was and then replaced it
Pump players UNITE
#6 RidinDirty
RidinDirty
  • 11 posts
Posted 01 October 2008 - 08:28 PM
Sounds like you needed to replace the bolt guide o-ring. Your local shop might have taken advantage of your situation.
"I firmly believe that any man's finest hour - his greatest fulfillment to all he holds dear is that moment when he has worked his heart out in a good cause and lies exhausted on the field of battle - Victorious."
-Vince Lombardi
#7 Yoda
Yoda
  • 425 posts
Posted 01 October 2008 - 08:37 PM
If it comes out of the breech/bolt, its not the noid, its the orings on the bolt/bolt guide. The noid doesn't send air down the breech, it pressurizes the chamber behind and around the bolt.
#8 Tunderwood
Tunderwood
  • 53 posts
Posted 01 October 2008 - 09:48 PM
Dp noids shut off don't they , If they get over pressurized?
#9 lechoochpumpballer
lechoochpumpballer
    Pumper
  • 467 posts
Posted 01 October 2008 - 10:02 PM
ok, first of all now that the noid is replaced it works fine plus the solonoid wasnt clickeing when i fired it
Pump players UNITE
#10 Grammaton
Grammaton
  • 138 posts
Posted 05 October 2008 - 04:10 PM
That sounds pretty fishy to me, I don't know that id be so quick to trust ur local shop. If they did the repair for you they could have simply replaced ur bolt O-ring while they had the gun appart and saw it broken then said they gave you a new noid.
