Exploding air tank theory
17 replies to this topic
#1 **armor**
**armor**
    Reads more than he paintballs.
  • 677 posts
Posted 11 January 2009 - 12:49 PM
Okay, not that I don't believe Mike, but could you do an experiment and publish the findings of your research to the paintball community. I have a friend who does not believe that the pressure could set off your tank like a molotov cocktail.
Just a thought.
#2 brycelarson
brycelarson
    Show me the Data!
  • 8,596 posts
Posted 11 January 2009 - 12:54 PM
I'm not interested in testing anything that can kill me.
Sorry, this one is outside our scope at this point. I would suggest contacting the manufacturer of most of the tanks we use - Luxfer.
Luxfer gas cylinders
#3 SOUP
SOUP
  • 7,724 posts
Posted 11 January 2009 - 12:58 PM
kinda like this tank maybe?
---Indiana Baller---
#4 Lord Odin
Lord Odin
    3 may keep a secret if 2 of them are dead
  • 2,129 posts
Posted 11 January 2009 - 01:06 PM
Exactly, it's way too dangerous and expensive to test something like that. I'd reserve that for the Mythbusters. Here's my request video for them:
Note: This is just to have them prove the extremes and/or give entertainment value.
The regulator on that tank just broke off and turned it into a missile. It didn't explode like we keep hearing about.
#5 SABRE
SABRE
  • 541 posts
Posted 11 January 2009 - 01:13 PM
It's science, isn't it? How does your friend not believe that high pressure can cause combustion if a combustible material is present. I think a lot of paintballers take the pressure lightly because it's something they use on a daily basis. My full 4500psi tank actually scares me. That is A LOT of pressure, theoretically isn't it over 300,000 pounds of pressure in a 68ci? I'm not great with conversions.
<div align='center'><img src="http://i384.photobuc.../grazi_sig.png" border="0" class="linked-sig-image" />
I am Limerick Himmler. Use bad grammar and my stormtroopers take you to
the Concentrate on Grammar Camp.
:D
</div>
#6 Canadian_baller
Canadian_baller
  • 138 posts
Posted 11 January 2009 - 01:31 PM
High pressure is what causes combustin is desel engines, therefore any petrolieum product in your tank will detonate. Causing serious harm to to anyone around it
If you ball with an ][nvert put this in your sig
TechPB.Com Is My New PaintBall Home. If Its Your New PaintBall Home Put This In Your Sig.
#7 Tucan9999
Tucan9999
    You never go ass to mouth!
  • 5,576 posts
Posted 11 January 2009 - 01:47 PM
When there is Pressures THAT high there is heat... When there is heat there is fire... When there is oil and fire there is BOOM!!! thats to put it simply....
TIMMY MILITIA Cause its the only club with MUTHA FUCKIN SNAKES
Mod App
#8 brycelarson
brycelarson
    Show me the Data!
  • 8,596 posts
Posted 11 January 2009 - 02:12 PM
well, it's not the pressure BEING that high that causes heat. There's no more than ambient heat in your tank when it's full. The issue comes in when you fill the tank. Increasing the pressure increases the temperature. So, the possibility for explosion happens at the moment that it's being filled.
#9 cockerpunk
cockerpunk
    All the Dudes
  • 9,137 posts
Posted 11 January 2009 - 03:14 PM
the called auto-ignition, and many are here when they say a diesel engine uses it.
when you compress gases, they tend to get hotter. this is why compressors always have intercoolers, and such to keep the gas cool, so its easier to compress. turbos in cars work the same way.
as you compress the gas, its get really hot, and if there is anything that will oxidize in the tank, it will ignite.
#10 Kitty
Kitty
    Feline With a Gun
  • 5,442 posts
Posted 11 January 2009 - 03:30 PM
ask those people with stako tanks.
a couple of them have gone up
#11 Snipez4664
Snipez4664
  • 785 posts
Posted 11 January 2009 - 05:33 PM
Diesels run at what, 25:1 maybe? Without considering the octane (or cetane, resistance to detonation at any rate) number of gun oil, tanks are compressed to (4500/15) 300:1. Seems reasonable to me to expect the combination of heat and pressure could cause an explosion, especially if the oil was just aerosolized via the fill nipple.
This post brought to you by: Lurker
Owner/Operator/Lead Engineer - Lurker Paintball
Check out our products at Lurker Paintball
#12 Poe
Poe
  • 326 posts
Posted 11 January 2009 - 10:27 PM
The combustion will occur once the product of heat and pressure exceed a limit. In other words you could ignite the oil even if it was reasonably cold.... so long as the pressure was high enough.
Oil between tank and marker might only be pressurized to 800psi, but that's more then enough pressure at room temperature to ignite some lubricants.
#13 brycelarson
brycelarson
    Show me the Data!
  • 8,596 posts
Posted 11 January 2009 - 10:53 PM
I want to be clear here - we're not talking about any danger of a gun going off. We've been using paintball guns for going on 20 years with oil - and it's never been a problem. the 800-ish operating pressure of even the higher-pressure guns aren't a danger. 4500 psi tanks are what we're talking about here.
#14 Poe
Poe
  • 326 posts
Posted 12 January 2009 - 12:15 AM
Sorry if it sounded like I was saying a marker would catastrophically explode if lubed incorrectly. Markers are designed well enough that the worst anyone has to worry about is a leaky seal.
I was just trying to say high pressure is enough to cause ignition without additional heat. And some 'oils' have low enough flash points they can ignite at room temperature when pressurized with an oxidizer to 'as little as' 800psi.
800PSI is definitely enough to cause something like sewing machine oil to ignite. Also, ignite isn't detonate. Just because the oil is burning doesn't mean there will be a detonation/explosion.
I could place a couple drops of sewing machine oil in the filter of my old Spyder Compact and watch my HPA guage slowly rise as the oil first evaporates then burns. Not recommended..just saying.
#15 chewiestmonkey
chewiestmonkey
  • 2,944 posts
Posted 12 January 2009 - 12:51 AM
duuude 800 psi isnt enough pressure to cause any kind of paintball oil to ignite, people have been putting oil through their asa sc\ince paintball guns had asa's.
but maybe sewing machine oil, idk... that stuff is a realy really thin oil, isnt it?
My BST feedback thread: http://www.techpb.co...&mode=show&st=0
If you'r too busy getting even, you will never get ahead.
#16 CanadianBigGame
CanadianBigGame
    "IMPORTANT"
  • 843 posts
Posted 12 January 2009 - 02:58 AM
Hell a pile of rags soaked in oil will burst into flames in your garage, not take that oil and put it under 4500psi KABOOM
<!--coloro:#008000--><span style="color:#008000"><!--/coloro--><b>CHEERS</b><!--colorc--></span><!--/colorc--> - <b>TECHPB MUPPET</b>
<img src="http://i413.photobuc...ame1small1.jpg" border="0" class="linked-sig-image" />
#17 REMER
REMER
  • 355 posts
Posted 12 January 2009 - 03:24 AM
i am would love to see a video of the results but who ever tests it needs to make sure they stay safe cause it is a bomb if it does go up
#18 brycelarson
brycelarson
    Show me the Data!
  • 8,596 posts
Posted 12 January 2009 - 09:32 AM
Alright, this has turned back into "i am would love to see a video of the results" - I'm closing this thread.
NEVER PUT OIL INTO HIGH PRESSURE CONTAINERS.
DO NOT ATTEMPT TO "SEE WHAT HAPPENS"
DO NOT TEST THIS AT HOME!
