How To: build 100x o-ring rebuild kits for $20
142 replies to this topic
#1 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 17 January 2011 - 12:37 AM
Hey guys, just wanted to share a tip thats been on the nation's dye forums for years now and i thought id pass it on to you guys. ive been using this site for years and i've yet to have a complaint.
if you want to build massive o-ring kits for your guns, go to the website www.mcmaster.com, and order your orings in bulk for the same price as a 10x rebuild kit.
its not as straight forward as it could be, since its extremely detailed, but once you know what to look for, youll be set.
***New instructions kindly provided by Morgan-Crp.***
***Be sure to tell him thanks!***
1. First off, go to www.mcmaster.com
2. When the page loads up, youre going to want to scroll down until you see the section for "Sealing". Click "o-rings".
3. Then click on the box that says "Buna-N O-Rings"
4. A side bar will come up, at the top click O-Rings
5. Scroll down on the side bar and click
-"Round" for cross section
-"70 A" for Durometer
-"Buna-N" for material
6. Then scroll up on the side bar to ""AS568A Dash Number" where you can select your O-Ring sizes. Check your marker's manual for specific sizes. Here I used 011 as an example.
7. Then the window changes, there will be two blue links/numbers. Click the top one.
8. Next you need to select the number of packs you want, they come in packs of 100 so one pack will be enough.. Unless you have an O-Ring fetish..
9. Click add to order, and repeat for all the other O-Rings you need.
The orings come in clearly marked plastic bags. just go to wal-mart and pick up a $2.00 tackle box and youll be set with a 100X rebuild kit!
hope this helps everyone!
**** i should note that Urethane orings(the clear ones) that are found in some guns are fairly pricy, and since i dont personally order them from here, i didnt include them.
**** feel free to order them from this site, just note that urethane orings are not made of Buna-N(hopefully thats obvious) and the typical Durometer is "Shore A: 90" and not 70.
here you go guys.
the orings come in marked bags just like i said. they came to me in a padded envelope, but i didnt really bother including it.
the packing slip also labels the plastic bags they come in, so there should be any fear of getting the sizes confused.
Uploaded with ImageShack.us
combine the orings with a tackle box from walmart and some time in photoshop and you have a pretty functional tech kit-
front cover- an oring sizer (yes, that is oring monkey's oring sizer chart, i feel bad for removing their logos, but i didnt exactly have all the room in the world.)
inside cover- just some quick reference stuff for my DM. has which orings go where in the gun. also has some quick settings for my virtue board.
Edited by Pakistani, 28 February 2012 - 10:55 PM.
KPS Paintball VCU Rams Richmond Rage
If you need help with a Dye gun, PM me!
#2 darkshocker11
darkshocker11
    was the cake really a lie?
  • 2,231 posts
Posted 17 January 2011 - 12:41 AM
I smell a pin and first
#3 tippofthehat
tippofthehat
  • 128 posts
Posted 17 January 2011 - 08:57 AM
Thanks so much for this great post- this is fantastic.
#4 LieutenantDan
LieutenantDan
  • 1,373 posts
Posted 17 January 2011 - 10:55 AM
I can hear oringmonkey crying now...
My Feedback +5|-0
To HELL with georgia
#5 MikeT10
MikeT10
  • 433 posts
Posted 17 January 2011 - 11:03 AM
cool
#6 CousinsBaller
CousinsBaller
    My Logic is Undeniable
  • 1,272 posts
Posted 17 January 2011 - 11:22 AM
Doing this right now.
#7 sticktodrum
sticktodrum
  • 11,913 posts
Posted 17 January 2011 - 11:25 AM
:tup:
#8 MZinCamo
MZinCamo
    OG
  • 8,962 posts
Posted 17 January 2011 - 11:27 AM
Nice write up!
#9 CousinsBaller
CousinsBaller
  • 1,272 posts
Posted 17 January 2011 - 11:31 AM
For my gun, it's already at 11 dollars or so, for 3 of the 15 o-rings i'll be getting.
#10 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 17 January 2011 - 01:55 PM
out of curiousity, what gun is it?
to my knowledge, all of the standard Buna-N orings are ~$2.00 per 100
and thanks everyone, glad people find this useful
#11 Gab0999
Gab0999
    BL G6R is unfortunately better than the Ego11
  • 95 posts
Posted 17 January 2011 - 02:01 PM
Stickyyyyyyyyyy!
#12 LMFAO
LMFAO
  • 381 posts
Posted 17 January 2011 - 02:28 PM
Agreed. ^ Sticky!!
#13 boardsnroses1134
boardsnroses1134
    Mues Vires
  • 695 posts
Posted 17 January 2011 - 04:45 PM
Any one know what a standard tank o ring is?
http://www.techpb.co...howtopic=157643
that is my vibe. i want to sell it or trade it. thus you should click this link and buy/trade for it.
#14 Danny D
Danny D
  • 2,036 posts
Posted 17 January 2011 - 04:51 PM
015/90
#15 TheGuy
TheGuy
    I like lamp
  • 13,799 posts
Posted 17 January 2011 - 04:54 PM
NICE find.
Heres a question though, are the standard cheapest ones any weaker compared to oringmonkey or ansgear which use milspec grade orings?
#16 TK-421
TK-421
    Me So Horny! :D
  • 25,988 posts
Posted 17 January 2011 - 04:55 PM
Maybe we need a new thread, that's linked in the OP, that's got a list of markers, and which sizes the o-rings are? Everybody could do the research on their marker, and then post up in the thread as to which marker they have, and what size o-rings are needed.
#17 Senior SL8R
Senior SL8R
    World Domination.
  • 3,917 posts
Posted 17 January 2011 - 05:02 PM
Add in one of these, And you got yourself a nice parts kit.
http://www.specializ...tments-154.aspx
- Crew 343 - D5 -
#18 boardsnroses1134
boardsnroses1134
    Mues Vires
  • 695 posts
Posted 17 January 2011 - 05:05 PM
3.90 for a pack of 100 tank o-rings!!!!!!
#19 mpg2384
mpg2384
    USAF
  • 955 posts
Posted 17 January 2011 - 05:18 PM
Nice find, this will come in handy as it seems everyone wants to charge extra for a Angel A1 o-ring kit.
#20 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 17 January 2011 - 05:25 PM
NICE find.
ive been using these orings in all of my DM's since my first dm4 ages ago. ive never once had any problems with them.
i personally couldnt compare mil spec orings with these, but from my experience i doubt these will be any worse.
also, if anyone is actually concerned they do have military spec orings. they are double the cost for half as much. im sure youll still come out ahead if you bought them though.
if someone can do a write up, id be happy to link it.
Edited by Pakistani, 17 January 2011 - 05:27 PM.
#21 sparky1
sparky1
  • 498 posts
Posted 17 January 2011 - 07:25 PM
you can specify that you want MIL-spec o-rings, it's just it's like $8/50 o-rings.
#22 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 17 January 2011 - 07:33 PM
yep, thats what i saw as well.
i should also add, that if anyone is adamant about getting military spec orings, save yourself some cash by only ordering them for orings that will actually move.
personally, i think the concept of "mil-spec orings" is a little gimmicky when referring to paintball guns, but even if they do offer benefits, im certain those benefits will be pointless for a static oring that wont move.
Edited by Pakistani, 17 January 2011 - 07:35 PM.
#23 gamefreak054
gamefreak054
    BLuRGhh
  • 6,123 posts
Posted 17 January 2011 - 07:34 PM
Son of a bitch, I just bought a pm7 rebuild kit like 2 hrs ago
#24 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 17 January 2011 - 07:41 PM
ouch... sorry bud
#25 CousinsBaller
CousinsBaller
  • 1,272 posts
Posted 17 January 2011 - 07:42 PM
Bob Long Protege. One pack of 100 came up for almost 6 bucks.
#26 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 17 January 2011 - 07:48 PM
im assuming those were urethane orings or they aren't standard, non-rated orings?
like i said, i dont order urethane orings from them since they are so expensive to begin with.
most urethane orings either-
A.) almost never go bad
B.) can be bummed from your local shop for a dollar or two
C.) can be replaced with Buna-N orings (although it might be a good idea to order a higher shore rating than the standard 70)
#27 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 18 January 2011 - 06:19 PM
2nd page owned. mind the bump.
#28 RickT
RickT
  • 367 posts
Posted 22 January 2011 - 02:16 PM
the metric one that cost 12 bucks ><
36 bucks for all the orings in the protege
#29 BrownChickenBrownCow
  • 424 posts
Posted 22 January 2011 - 03:42 PM
McMaster-Carr is a fantastic company. That's where I order my Dow 55 and Triflow from. I ordered it one night after 5 pm and had it the next day, all for under $40. Granted I'm 60 miles away from the warehouse in Chicago, but still amazingly quick for UPS Ground. I actually use them all the time at work, but I never thought about ordering o-rings from them. Guess I'll be making another order really soon!
#30 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 22 January 2011 - 03:52 PM
36 bucks for a 100x oring kit isnt bad!
im going to be placing an order from them extremely soon, ill be sure to post pictures of how the orings come.
#31 RickT
RickT
  • 367 posts
Posted 24 January 2011 - 05:21 PM
NOOOOO
respond email from the company Thank you for your order. Unfortunately, due to the ever increasing complexity of United States export regulations, McMaster-Carr will only process orders from a few long-established customers in Canada. We sincerely regret any inconvenience this causes you.
Any one one would like to place my order and ship it out to a follow player?????????????
#32 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 28 January 2011 - 06:33 PM
ordered my oring kit today.
ill post up pictures and what not when it arrives.
#33 ThunderLights
ThunderLights
    Turbocharged Member
  • 9,202 posts
Posted 28 January 2011 - 07:20 PM
wow this really should be a sticky.
#34 Rollieelmo
Rollieelmo
  • 3,033 posts
Posted 28 January 2011 - 07:42 PM
Nice find. Now I don't have to pay $20 for 100 o-rings.
And this is a trusted site?
Edited by Rollieelmo, 31 January 2011 - 03:06 PM.
Rockin' Cocks Revolution
#35 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 31 January 2011 - 06:12 PM
wow... ordered these friday at 4pm and theyre already here.
i love mcmaster!
pics up when i get home to take them.
#36 Maj Tom
Maj Tom
  • 2,660 posts
Posted 31 January 2011 - 06:29 PM
NOOOOO
I'll be putting an order in later this week for some stuff if you want me to throw your items on there.
As for the thread, yep McMaster is a good site been ordering from them for years. Usually only takes 1-2 days to get to me from Ohio.
But the site is a little buggy on some items, when you use their "guided search" type thing. Sometimes they won't give you the option you are looking for, so you might need to go back and try a different sequence.
Overall a good site to know about:
Springs, bolts, orings, macro, fittings and lubricants all in one place.
Edited by Maj Tom, 31 January 2011 - 06:34 PM.
#37 gamefreak054
gamefreak054
    BLuRGhh
  • 6,123 posts
Posted 31 January 2011 - 06:33 PM
hmm couldnt get mcmaster to work. but I found hustler sells 100 packs of tank orings for $5 anyways.
Edit actually $4.25
Edited by gamefreak054, 31 January 2011 - 06:37 PM.
#38 Hebiki
Hebiki
  • 7,220 posts
Posted 31 January 2011 - 07:00 PM
great find.. i was about to pull the trigger on a DM10 o-ring kit from ansgear.
milspec vs. reg... reg. is so cheap.. you can replace them after a day's play and still have better value than using "mil-spec" o-rings. :) will be putting together a DM10 kit real soon.
ALTHOUGH im lazy and i do kinda like the color coding. LOL
#39 RickT
RickT
  • 367 posts
Posted 31 January 2011 - 10:09 PM
NOOOOO
Thanks, I actually a local shop in Toronto.
Going to that shop 2mrw if the price is a huge different i'll msg you to take my order
#40 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 01 February 2011 - 01:33 AM
here you go guys.
Edited by Pakistani, 01 February 2011 - 01:37 AM.
#41 Hebiki
Hebiki
  • 7,220 posts
i love mcmaster!
Paki...off your example...you don't list the 007 UR90 o ring?
#42 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 01 February 2011 - 01:51 AM
i love mcmaster!
i dont list them because theyre so expensive.
those orings hardly ever go bad to begin with, and then spending the ~$8 for the pack just doesnt seem worth it to me.
im looking into replacing the UR orings with shore90 Buna-N orings.
#43 Omegaexcellens
Omegaexcellens
  • 145 posts
Posted 01 February 2011 - 06:19 AM
Why hasn't this been stickied yet?!
+1 for a sticky!!!
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction." -- Albert Einstein
#44 EricCartman
EricCartman
    Senior Member-LL4 Vet
  • 2,056 posts
Posted 01 February 2011 - 12:44 PM
i demand sticky status on this thread.AWESOME FIND!!!
#45 Hibiki54
Hibiki54
    Lord of the Western Lands
  • 2,949 posts
Posted 01 February 2011 - 12:45 PM
Someone needs to sticky this here and in the Budget Ballers forum.
#46 Hebiki
Hebiki
  • 7,220 posts
Posted 01 February 2011 - 01:53 PM
i love mcmaster!
hehe.. yah i just saw your thread asking this on the "other" forum. :lol: :D you're right, I'll probably sell the marker before those o-rings go bad. :)
#47 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 01 February 2011 - 09:07 PM
i love mcmaster!
Yep, turns out its perfectly fine to replace UR orings with Buna-N's in dye regs.
ordering them now :)
i dont know if its looked down upon... but can we sticky this thread? haha
#48 Hebiki
Hebiki
  • 7,220 posts
Posted 02 February 2011 - 04:24 PM
MODS.... please sticky this!
i can post DM10 o-rings if anyone is interested.
#49 Gee-oh
Gee-oh
  • 307 posts
Posted 05 February 2011 - 10:19 PM
bump :)
Black ND Blue G6R
Dye Rotor
68/45k SLP
Looking for an Ego 11
#50 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 06 February 2011 - 12:37 AM
^ thanks.
just rebuilt my dm9 completely using the mcmaster orings and its working just fine!
no leaks, cycling fine, and my settings are right where they were with the stock dye orings.
these are legit guys!
