quest problem
#1 paintballer008
paintballer008
  • 189 posts
Posted 21 June 2011 - 04:51 PM
I have my quest that I'm trying to repair, at the moment it is leaking a large amount of air through the solenoid or right before it gets in it. I took apart the frame so I could pin point where the leak was coming from and it was coming through the solenoid. I also tried shooting the gun with the leak and it would shoot a little amount of air like the solenoid was blown.
I bought a noid on here from a guy who said has never used it and put it in and had the same problem. I replaced the bolt o-rings and had the same problem. I have an older board so I don't have a manual to reset it back to stock settings, is there anythings else I should try?
Thanks
#2 hogzilla88
hogzilla88
    Something about narwhals...
  • 4,569 posts
Posted 21 June 2011 - 05:13 PM
I have a similar issue with mine, I was told by critical that it was the valve core, only a $12 part.
#3 paintballer008
paintballer008
  • 189 posts
Posted 21 June 2011 - 06:05 PM
let me know if that works
