Dangerous Power G4 V.S Smart parts SFT Shocker
5 replies to this topic
#1 DJ Brain Dead
DJ Brain Dead
    The Baby Punter
  • 260 posts
Posted 12 August 2011 - 07:44 PM
Trying to figure out which marker is better I am a back to middle player, and play woodsball also, so im trying to figure out which one shoots and just is plain better in others opinions.
Yeah I use an Invert Mini.... You got a problem wit that?
#2 Cutterj
Cutterj
    I shoot people.
  • 318 posts
Posted 12 August 2011 - 11:46 PM
Proto rail
/thread
#3 nighthunter
nighthunter
  • 4,104 posts
Posted 13 August 2011 - 12:05 AM
Shockers are IMO one of the nicest spoolies you can get for under $500. They shoot really smooth and quiet. You can pick up one with insane upgrades for a steal if you shop around. Only thing Shockers were never really good for was efficiency, but neither is the G4.
If you decide to get a Shocker, here are some upgrades to look for:
1. Feedneck (stock feedneck was a cheap stovepipe. make sure it has an aftermarket feedneck.)
2. Board (most early boards were semi-auto only. if you want more modes, get one with an aftermarket board)
3. ASA (not a showstopper, but the stock asa doesn't purge)
4. Reg. (more a matter of convenience since the stock reg works fine but requires a special wrench to adjust properly.
If you give a Shocker some good maintenance, it will never break on you. Hopefully this helps
#4 DJ Brain Dead
DJ Brain Dead
    The Baby Punter
  • 260 posts
Posted 13 August 2011 - 12:20 AM
Well thanks that helps a lot, I found a pink shocker, and a dynasty shocker, both are good but just looking thanks tho, if I get the pink i will look for the upgrades thanks a lot!:)
#5 tubberthump
tubberthump
  • 286 posts
Posted 13 August 2011 - 12:23 AM
get them with the upgrades and save a bundle
#6 DJ Brain Dead
DJ Brain Dead
    The Baby Punter
  • 260 posts
Posted 13 August 2011 - 12:27 AM
ok thanks for the help!
