Dye DM7 Trigger problems :(
1 reply to this topic
#1 Joeisawesome
Joeisawesome
  • 113 posts
Posted 02 January 2012 - 02:28 AM
After a day of play on the 30th my gun was shooting great with no problems at all. A little later in the day I let my friend shoot a pod through it, but when he was finished with the pod, something was wrong with the trigger. I took it home thinking nothing of it, but when I went to actually fix the problem I ended up working on it for a couple hours. It seems nothing will fix the trigger problem. I'll list the problems below.
It is a cp Sling trigger, and the trigger will continuously depress the microswitch, making the gun only fire once. The trigger does not retract, so it almost seems unresponsive with no reacting force. I did not take or remove anything prior to this happening, so it could not have anything to do with a careless error.
PLEASE HELP! I need to know if I need replacement parts, or perhaps where I could get this fixed.
Thanks
IF YOU ARE A FLORIDA BALLER PUT THIS IN YOUR SIG! :D
#2 dirtraven
dirtraven
  • 39 posts
Posted 02 January 2012 - 11:24 PM
is the return spring still in place?
