Tips on dorito corner and dorito
15 replies to this topic
#1 TECHDP=)
TECHDP=)
    I'm never online anymore.
  • 8,876 posts
Posted 03 January 2012 - 01:39 AM
Any tips/advice is helpful.
Usually when I play, I can't stop staring at animated gifs on my smart phone like this one-
  • 22,420 posts
Posted 03 January 2012 - 01:45 AM
A good dip is nice. I like to go with a chunky salsa... oh, wait, you were talking about the paintball Doritos... silly me.
Sorry, I have no actual advice, but I'm entering caffeine withdrawals right now, so that's probably a lot funnier in my head.
#3 TECHDP=)
TECHDP=)
  • 8,876 posts
Posted 03 January 2012 - 02:30 AM
Mmmmm doritos yum.
#4 Kirko017
Kirko017
    Say no to drugs!
  • 1,250 posts
Posted 03 January 2012 - 04:47 AM
Get up them fast and shoot everyone out. You don't always need a 2 guy operation in the doritos. One can usually suffice. Instead of going corner, go up the middle, try to grab some ground and do some work there. You can always fill out to the doritos later if your guy gets out..
Edited by Kirko017, 03 January 2012 - 04:48 AM.
#5 epikfailpaintball
epikfailpaintball
  • 376 posts
Posted 03 January 2012 - 10:38 AM
ALWAYS KNOW HOW TO PLAY YOUR BUNKER. If you play dorito make sure your marker is angled with the dorito so your hopper doesnt come out first. Same goes for any bunker. Make sure your gun is at the same angle as the bunker so you have a tight snap. Also if you have to play tight in dorito, depending on the situation, I sometimes tuck my knees underneath the dorito so I can play tight
#6 TECHDP=)
TECHDP=)
  • 8,876 posts
Posted 03 January 2012 - 03:35 PM
Im big . 6'2" and like 230lbs
So it can be hard to play tight sometimes haha
#7 chappinpaint
chappinpaint
    the /thread guy
  • 1,986 posts
Posted 03 January 2012 - 05:11 PM
play dorito like you would snake. shoot inside and play tight as hell. also make sure someone is covering your ass on the tape.
i sigged myself once
#8 meta2
meta2
    Resident Drama Geek.
  • 368 posts
Posted 03 January 2012 - 05:24 PM
Get into it like it's your girlfriend. If you have a tape, shoot inside. If you don't, then keep a look out on the tape side for what's happening. Protip: Have a tape. It makes your life over 9000 times easier.
Don't bump unless you know exactly what's going to happen.
KCMECustoms= Bob Long has never had amazing packaging but if you put a turd in a tuxedo its still a turd.
#9 TECHDP=)
TECHDP=)
  • 8,876 posts
Posted 03 January 2012 - 06:31 PM
fersure. i usually play corner.
but when i bump up to dorito is when it gets not so easy
#10 m4ndark
m4ndark
  • 1,287 posts
Posted 03 January 2012 - 09:30 PM
its basically the same for the snake
shoot inside while the corner get your tape.
and stay calm, if they are shooting at you and you can do nothing, great! that means that they arent shooting on your friends and so they can advance.
when snake side is clear or you team cant advance becouse of you mirror ( d1,d2,d3 ... ) is there, thats time to bunker, puut his corner in and run the tape as fast as you can, so you dont take shoots from the inside and actually bunker the guy before the backcenter/corner/snake shoot you.
Brazil- passionate baller
#11 BURN177
BURN177
    super man that ho
  • 1,058 posts
Posted 04 January 2012 - 01:19 AM
make sure you watch for people filling into the snake cross field. move up and look inside most of the time but check down tape often. move up when you KNOW whats ahead. I'm 6 feet so I know it's hard to play tight but you gotta try when it gets heavy. watch the snake alot cause if some one gets inside the snake they will be shootin at you. If someone does get in keep some steady paint on them not 12.5 but just a few that way if they pop up you can give them a little 68 caliber surprise!
hope that helps.
#12 TECHDP=)
TECHDP=)
  • 8,876 posts
Posted 04 January 2012 - 01:28 AM
Thanks.
Who did this lol.
#13 Hebiki
Hebiki
  • 7,220 posts
Posted 12 January 2012 - 03:17 PM
you need to come out to ASG.. or SCVillage.. and just keep playing. :tup:
do what i do.... TRY IT in a real game..and i always find out REAL fast if it was a good idea or not. :P :o :lol:
#14 TECHDP=)
TECHDP=)
  • 8,876 posts
Posted 12 January 2012 - 06:44 PM
i go at least 3 sundays a month to sc.
and lol
#15 Hebiki
Hebiki
  • 7,220 posts
Posted 18 January 2012 - 04:14 PM
we'll be there sat at SCVillage. :) gonna do some walk on and streetball. :)
#16 TECHDP=)
TECHDP=)
  • 8,876 posts
Posted 19 January 2012 - 12:34 AM
Expect rain.
