fusion fx out of box reg air leak?
#1 H2ONIGHTHAWK
H2ONIGHTHAWK
  • 12 posts
Posted 15 January 2012 - 10:40 AM
I had just got my dangerous power fusion fx and got it ready to fire. now coming new out of the box I took out all of the dp lube and used tech t gun sav lube before shooting the marker... then i notice a small air leak coming from the regulator if anyone has any suggestions please let me know thankx.
Edited by H2ONIGHTHAWK, 15 January 2012 - 11:10 AM.
#2 mjblount
mjblount
  • 1,304 posts
Posted 26 January 2012 - 08:26 PM
Take apart the reg clean and lube it and check orings. Also make sure the poppet is completely dry
Guns I've owned:(in order) Ego 6, PM8, Etek 3lt, Ego 10, Dangerous Power FX
My favorite ones: Ego 6, Ego 10, Dp FX
#3 littleloopy15
littleloopy15
  • 3,116 posts
Posted 26 January 2012 - 08:29 PM
from the regulator or from the fitting? If it is actually from the reg, just do what mjblount said to do, re-lube the reg.
Feedback 17/0/0
#4 H2ONIGHTHAWK
H2ONIGHTHAWK
  • 12 posts
Posted 27 January 2012 - 12:20 PM
yea i fixed the problem it was the macro line fitting on the reg.. i took the fitting off and used blue locktite and it works flawlessly now. thanks guys :D
#5 Rotozip2
Rotozip2
    BRO do you even autococker?
  • 3,432 posts
Posted 27 January 2012 - 03:46 PM
Wait... Are you using grease on the rammer?
