Help with flexs!
#1 Will McCarthy
Will McCarthy
  • 9 posts
Posted 01 October 2008 - 05:35 PM
hey alrite my team just won flexs at the last tournament we did and i was jus wondering wat i need and where to get it. We only got bottoms and frames with tinted lens, i need a strap, soft ears i think and wat else....is ther somehtin that i need to hold the ears in place or sumthin thanks!! :unsure:
#2 Ant
Ant
  • 448 posts
Posted 01 October 2008 - 05:36 PM
Frame
Bottoms
Lense
Ears and hardware for ears
Strap
|SDA Fan #1|XSV Fan #1|Canes Fan #1|
Lethal Ballers
War does not determine who is right-only who is left.
-Bertrand Russell
#3 Will McCarthy
Will McCarthy
  • 9 posts
Posted 01 October 2008 - 05:43 PM
where can i get the soft ears and hardware for ears is rele wat im wantin to no thanks!
#4 pandemic3
pandemic3
  • 71 posts
Posted 01 October 2008 - 05:59 PM
usually any paintball store has them.
some may not carry them as regular stock but can possibly custom order some for you and your team
try a couple online stores such as PEVS, actionvillage,etc they should have them and sell them for 20 bucks at the most and you can get them shipped to you for a little bit more. I may be wrong in terms of the the stores having stock for the products but they should be able to help!
You could also try a couple canadian stores such as
www.badlandspaintball.com
www.canadianpaintball.com
www.premiumpaintballproducts.com
shipping may be a pain but it would be worth it
if you're looking for some style try KM they make custom straps and they look sick so they'll go with your flex no matter what colour and it won't look generic!
COC #3
Connor: The rule of thumb here is...
Rosengurtie: Wait, rule of thumb? In the early 1900s it was legal for men to beat their wives, as long as they used a stick no wider than their thumb.
Connor: Well, can't do much damage with that then, can we? Should have been a rule of wrist.
#5 zar2d2
zar2d2
  • 11 posts
Posted 01 October 2008 - 10:01 PM
softearmods.com - they come with hardware
