need autococker help!
5 replies to this topic
#1 WiscoBaller
WiscoBaller
  • 2,655 posts
Posted 07 February 2012 - 07:38 PM
Hey guys,
I bought an oddessy O3M cocker, and halfblocked it. I then put a pump kit on it. Now the cupseal is broken, but my friend told me that i dont have a standard autococker valve. Can you tell me if an autococker valve will fit in this cocker?
The Hooligans Paintball Team
Bob Long Ripper FST
#2 hogzilla88
hogzilla88
    Something about narwhals...
  • 4,569 posts
Posted 07 February 2012 - 08:15 PM
It might be an 11/16 valve.
#3 WiscoBaller
WiscoBaller
  • 2,655 posts
Posted 07 February 2012 - 09:12 PM
what would be the best valve for it?
Bob Long Ripper FST
#4 DamianE
DamianE
  • 253 posts
Posted 08 February 2012 - 08:12 PM
i vaguely recall back in the day someone saying that the merlin an oddessy o3m share the same non-traditional valve size. if so a madman or tornado valve will fit. but i would wait for someone else to corroborate this...it was a long time ago
#5 The Inflicted
The Inflicted
    ⊥ɥǝ Iuɟl!ɔʇǝp
  • 2,455 posts
Posted 08 February 2012 - 10:52 PM
Just because the valve is different doesn't mean a standard 'cocker cupseal won't work.
If I'm not mistaken, that valve size is actually Spyder-spec.
Spyder and 'Cocker cupseals are interchangable for the most part, though the metal stems are not.
Before you buy a new cupseal, you might be able to restore the old one but running the sealing face back and forth across some fine grit sandpaper. Doing that will often create a nice smooth surface that allows it to seal again like new.
#6 Demon
Demon
    Master Tech
  • 2,087 posts
Posted 09 February 2012 - 10:12 PM
take the reg off run 850 psi through the gun if you can get it to not leak. let it sit overnight and in the morning the cup seal will have reformed and will seal properly. a slick trick a good friend of mine showed me, and he has been building his own cockers and working as a local teching god at MPG (sniff they closed) for a long time.
Mad Cow Paintball referee and tech
UNL Husker Paintball
"Let's play a game of go fuck yourself, you first..."
