Tank help
#1 DENNI740
DENNI740
  • 223 posts
Posted 14 April 2012 - 02:00 PM
Hello all,
My dad claims he has like 6 air compressors that can get to 4.5k psi. Could I use just any pump with the right hose to fill my tanks or does it have to be a paintball specific one? And if it is possible, what are the steps to fill a tank?
#2 Empire91
Empire91
    Pump Zen Master
  • 2,592 posts
Posted 14 April 2012 - 02:22 PM
Any compressor will work, but the hoses need to be rated safe for those kinds of pressure. Then you just plug your tank into the fitting and let it fill.
#3 DENNI740
DENNI740
  • 223 posts
Posted 14 April 2012 - 02:35 PM
Do I need to buy anything special?
#4 NJC
NJC
    pumper
  • 3,396 posts
Posted 15 April 2012 - 01:01 AM
the right hose and collar. but otherwise no
*Waits to get hit*
#5 K.YO
K.YO
  • 2,974 posts
Posted 15 April 2012 - 01:14 AM
yeah as long as you use the right hose and fittings and it shouldnt be a problem. Also if the compressors can fill past 4.5k (or if you are filling a 3k tank), make sure that you keep a close eye on your tank while it is filling
No, I plan to Gears of War roll into a hut, shoot a motherfucker right in the face, one arm cock that bitch like on the movies and blow a cowering 9 year old right out the goddamn window while yelling hufuckingzah bitches.
