Spec R Bolt Problem
#1 redsoxfanjoe
redsoxfanjoe
  • 131 posts
Posted 14 April 2012 - 07:54 PM
G3 Spec R
L7 Tech T Bolt for G3
Rampage Board
No leak when the ASA is turned on, but the regulator was screwed tight. As soon as I open regulator the board slides forward and there is a clear leak through the bolt. I checked all the orings but none of them are damaged. Its lubed with smart parts greese. Any ideas?
***put new orings on it. when gased and regulator on, the bolt is forced forward but the bolt won't go back and thats why the air is leaking.
Edited by redsoxfanjoe, 14 April 2012 - 08:30 PM.
  • 22,432 posts
Posted 14 April 2012 - 08:02 PM
Is there an o-ring/groove on the bolt tip?
The Spec-r uses a different bolt than the G3, so if you have the regular G3 engine, that's why it's not working in your Spec-r.
Edited by andrewthewookie, 14 April 2012 - 08:03 PM.
#3 redsoxfanjoe
redsoxfanjoe
  • 131 posts
Posted 14 April 2012 - 08:06 PM
if you google it you can see what it looks like, there is one on the tip but at its base
#4 redsoxfanjoe
redsoxfanjoe
  • 131 posts
Posted 14 April 2012 - 08:17 PM
i've researched, i made sure it was the spec r bolt system. so still i have a problem
Edited by redsoxfanjoe, 14 April 2012 - 08:22 PM.
#5 andrewthewookie
  • 22,432 posts
Posted 14 April 2012 - 08:19 PM
This one is for the G3:
This one is for the Spec-r/G4
