Coding problem in Guide
No replies to this topic
#1 MMMerc
  • 1,712 posts
Posted 25 April 2012 - 12:41 PM
Hey guy's, um... having a problem with my guide, as you see in the pro tips section, there is a spoiler, its meant to look like:
In case anyone is still doubting, I took a couple pics to illustrate just what happens when you tilt your gun behind a vertical bunker (vice a dorito. The key thing is that if you are keeping your gun pointed at a specific target, your barrel becomes the axis around which you are rotating the gun.
In the following pics, the camera is positioned (as best I could) to be looking straight down the barrel, with a yellow reball in the breech. Because of the camera and barrel orientation, the pics depict what your target would see if you were pointing at them.
SP-1 with hopper and 68ci tank:
Vertical- Tank, feedneck and hopper are all partially visible.
Rotating the hopper in, while aiming at the same target, rotates the tank outward. Tank fully visible before the hopper and feedneck are fully concealed.
when the spoiler pops up, however instead of the pictures, im getting this weird resizing to infinity thing, such as:
Edited by MMMerc, 25 April 2012 - 12:42 PM.
