Tippmann U.S. Army Alpha Black Problem
6 replies to this topic
#1 PaintballHazard
PaintballHazard
    Speedballer
  • 902 posts
Posted 08 March 2009 - 01:12 AM
I won an Alpha Black at a scenario game (I didn't buy it, so don't flame me for having one).
To keep this short, it will not blowback. It is "cocked", I fire, and I have to "recock" it to fire another ball.
YES:
I have air
I have enough air
I have used my tank on this gun before
I have oiled it
I have cleaned it
I have checked it to see it's internals
It has every part in it
Indiana Member #2 Retired TechPB user
#2 quackSH
quackSH
  • 1,619 posts
Posted 08 March 2009 - 01:24 AM
the only reason that it would need to be recocked is because the air or CO2 pressure is not enough to push the bolt back, u should just call Tippmann
#3 lavalettenj
lavalettenj
    Super Elite Senior Master Member
  • 683 posts
Posted 08 March 2009 - 09:47 AM
I agree call Tippmann. Or take it to a tech.
#4 Evil Fingers
Evil Fingers
    Banned
  • 5,835 posts
Posted 08 March 2009 - 11:28 AM
Before hittin up Tippmann your problem with the ABT, check the Main Drive Spring, it might be to he point that the Main Spring is so Compressed that its unable to let the Rear Bolt when it cycles back to catch the Sear.
#5 motoguy1251
motoguy1251
  • 1,086 posts
Posted 08 March 2009 - 11:55 AM
If it has the 98c style detent make sure it isnt backwards.
Ferris State University Paintball Club President
Cocker Commando Army
#6 PaintballHazard
PaintballHazard
    Speedballer
  • 902 posts
Posted 08 March 2009 - 01:06 PM
Thanks guys. I'll try to get my hands on some air or CO2 before next weekend.
My latch isn't backwards, that was one thing I first checked.
Thanks for all the feedback
#7 SOUP
SOUP
  • 7,724 posts
Posted 08 March 2009 - 01:11 PM
Check your velocity as well hazzard. It is most likely not the problem but my vs3 had that problem and would do the same thing. I cranked it up and it worked fine after that. Hopefully you get it fixed before saturday, If not we can try and fix it there.
See you at Bastogne...
---Indiana Baller---
