Drone Dx volet trigger problem
1 reply to this topic
#1 Overlord
  • 138 posts
Posted 17 May 2012 - 02:16 AM
So my brother got himself a new trigger for his Drone,but when I tried to install it,I just can't install it properly.It seems that some thing on hte trigger is missing,when I install it the upper part just goes into the trigger frame,there is surfce that can support pre travel screw.What can I do about that?I thought that Clone and Drone trigger are the same and comaptible.
#2 Paintball48
  • 74 posts
Posted 10 October 2012 - 04:48 PM
You can't use the violent trigger on the drone unless you sand it down a little but if you buy the critical trigger it will fit
