Ego 8 Problem. Help PLEASE
1 reply to this topic
#1 Supra92
  • 12 posts
Posted 27 May 2012 - 12:22 PM
Hi, I recently got an ego 8 and found that air is not getting to the noid. Has anyone had this problem before? If so how can I fix it?
#2 No Mercy Ever
No Mercy Ever
  • 549 posts
Posted 28 May 2012 - 10:44 AM
Okay, the most likely culprit is most likely the hose that goes from the LPR to the solenoid. So very carefully, you need to disassemble the marker to check that it isn't pinched or what have you. If that is fine, then check the air passage from the solenoid barb to the LPR. Then check the VASA to make sure that air is going from the HPR to the LPR. If it isn't one of those, then check your solenoid to make sure that it is working properly.
