just put in a couple of orders for some parts ....
8 replies to this topic
#1 cockerpunk
cockerpunk
    All the Dudes
  • 9,137 posts
Posted 04 June 2012 - 01:12 PM
http://www.digikey.c...rds=223-1018-ND
http://www.digikey.c...x=0&y=0&cur=USD
mmmmmmmm, gonna be fun ....
#2 UV Halo
UV Halo
    Bringing the Big Guns to LLVI
  • 1,631 posts
Posted 04 June 2012 - 01:24 PM
Looking to do some hardcore reg testing? Or would it be Breach Pressure?
#3 cockerpunk
cockerpunk
    All the Dudes
  • 9,137 posts
Posted 04 June 2012 - 04:03 PM
gordon cocker-transducer-punk here
#4 supertux1
supertux1
  • 159 posts
Posted 04 June 2012 - 06:11 PM
HPA reg testing? Screw the transducers into the burst disc ports, measure voltage?
RCTIME fun!
Edited by supertux1, 04 June 2012 - 06:12 PM.
#5 The_Economist
The_Economist
    It's business time.
  • 2,363 posts
Posted 05 June 2012 - 10:19 AM
Finally gonna test that Magic Box, eh?
#6 Cap'n Biff
Cap'n Biff
    Lab Ogre
  • 700 posts
Posted 07 June 2012 - 04:55 PM
Hmmm... HPR feedback to automatically adjust dwell on a shot-by-shot basis, based on available pressure. As the pressure drops and the reg O/P becomes less efficient/consistent, dwell is corrected to maintain a consistent shot...
So, CP, what exactly ARE you gonna do with your new toys...?
Paintballs bounce off me like raisins off an Oldsmobile...
Lapco BigShot Assault A5 14"
#7 Egomaniacal
Egomaniacal
  • 139 posts
Posted 07 June 2012 - 10:22 PM
With regs as stable as they are these days, there's really no need for this.
What made you choose 1k and 5k? Seems like your ranges overlap significantly, unless of course you're doing simultaneous measurement.
Oh duh, you're testing tank regs. Supertux1 called it.
Edited by Egomaniacal, 07 June 2012 - 10:23 PM.
eiπ = − 1
#8 y0da900
y0da900
  • 120 posts
Posted 08 June 2012 - 07:28 PM
Now you need to snag a can of spray on foam insulation and a roll of Saran wrap, and do a comparison between measured shot to shot energy consumption determined through pressure monitoring of a near thermally isolated vessel and compare the theoretical numbers to a complete traditional efficiency test.
What are you using for data capture? I know that nicad used to use (or still might) a Stingray USB oscilloscope/data logger for testing purposes.
#9 azreal
azreal
  • 176 posts
Posted 02 July 2012 - 04:01 PM
What are you using to record? Hooking to a oscilloscope or some sort of DAC?
