Help With Broken tube on Ion?
#1 kirkf22
kirkf22
  • 2 posts
Posted 13 June 2012 - 01:53 PM
I just bought an ion off of eBay. I put in the air and tried shooting but it wouldn't shoot and I could hear air leaking. I took it apart and it seams that inside it, one of the two tubes that is like screwed into the barrel is broken. The tube isn't broken just the screw that holds it in, it is cut in half. I can't secure the tube to the barrel thing because it won't screw in due to the screw being broken. This Is Why air is not getting to the barrel to propel the paintball. I'm 16 and this is my first paintball gun so I have no idea what to do. Any advice is greatly appreciated.
Edit: it might be a banjo?
Edited by kirkf22, 13 June 2012 - 03:15 PM.
#2 firebirdjimbo
firebirdjimbo
    Arms Dealer
  • 1,333 posts
Posted 15 June 2012 - 12:26 AM
Yep, one of your banjo fittings was over-tightened and it sheared off. Going to have to get an "easy out" extractor bit to remove it. Then buy a new banjo and install it being careful not to over-tighten it
fistful of agg. MN ballers club, the modders guild.
My Feedback +6/-0
I FIX BROKEN GUNS
#3 kirkf22
kirkf22
  • 2 posts
Posted 15 June 2012 - 08:58 AM
Ok if it doesn't come come out, do I buy a new breech section?
