Kaos Pump vs Trilogy with pump kit.
7 replies to this topic
#1 q000ball
q000ball
    i Fought The Law, And....I Won
  • 401 posts
Posted 21 June 2012 - 01:32 PM
the KP the guy wants $100 and it has brand new macro and fittings but no screws for the detents but apparantly you can just glue the cover on and it works fine,
Or
a trilogy with a pump kit on it for $70
#2 purpleninja23
purpleninja23
  • 35 posts
Posted 21 June 2012 - 06:14 PM
Hmm, is the kp first or 2nd gen? That would make the difference in my opinion.
#3 q000ball
q000ball
  • 401 posts
Posted 21 June 2012 - 06:42 PM
haven't seen any picture so cant tell for sure, but i'm thinking its a first gen
#4 purpleninja23
purpleninja23
  • 35 posts
Posted 21 June 2012 - 07:41 PM
Alright if its a first gen i would say the trilogy. Thats my opinion so if anyone disagrees, please post it and tell me why.
#5 G4paintballer
G4paintballer
    Gun/gear whore
  • 5,862 posts
Posted 21 June 2012 - 07:42 PM
Trilogy, all the wayyyyy.
$12 spring kit and it's smoother than the KP.
It's already more quiet, more efficient, and has much more modification options.
Feedback 10/0/0
#6 q000ball
q000ball
  • 401 posts
Posted 22 June 2012 - 05:58 AM
finally got to see pictures, and it turns out it is a second gen KP. at least i'm pretty sure it is, because it has an actual regulator on it instead of just gas through grip.
#7 JunkedDuck
JunkedDuck
  • 21 posts
Posted 22 June 2012 - 01:33 PM
Trilogy
cheaper and the trigger is close to a single trigger, plus u can add a cheap reg, macroline, and fittings for just a little more than $100 total
Edited by JunkedDuck, 22 June 2012 - 01:35 PM.
#8 Hitman2513
Hitman2513
    Save a Rock Throw a Mini
  • 5,995 posts
Posted 23 June 2012 - 07:08 PM
Bitches love my Spyder Ion
