Sound Card question
7 replies to this topic
#1 thepaintballkid
thepaintballkid
    Farcaster
  • 1,935 posts
Posted 08 July 2012 - 02:22 PM
Alright well I do not have a sound card in my computer. I know I could find some fairly cheap but was wondering if I could plug in a external sound card (the cheap USB ones) and have it work with me just using headphones.
#2 Blade of grass
Blade of grass
  • 3,225 posts
Posted 08 July 2012 - 03:42 PM
Of course it would, that's what they are designed for.
But really, you Desktop or laptop will have pretty good on oars audio, so just use that.
#3 Stix
Stix
    TechPB Lurker
  • 1,509 posts
Posted 08 July 2012 - 06:34 PM
What Blade said, on board will be more than good enough for 99% of people.
xfire-stix9693
Ps3 - SLYGATHOR (LittleBigPlanet, Burnout Paradise, Team Fortress2, Killzone 2)
Wii - 5318 0896 2208 0310
Steam - slygathore
Building a computer is like playing with Legos, the pieces only fit one way
#4 The Bacon Man
The Bacon Man
  • 4,201 posts
Posted 09 July 2012 - 06:15 PM
I think he means he doesn't even have on-board audio. In that case, go for the USB.
#5 TacticlTwinkie
TacticlTwinkie
    *insert witty title*
  • 3,974 posts
Posted 09 July 2012 - 06:31 PM
If you have on board audio on the motherboard, there is no need for a sound card unless you have a high end sound system plugged into it. The on board audio is more than sufficient for regular speakers and most any headphones. If your on board audio isn't working or it doesnt have on board audio for some reason, a cheapy usb one should suffice. But if you can score an inexpensive internal one or are willing to buy an internal one (they really arent that expensive for half way desent cards) go for it.
#6 Stix
Stix
    TechPB Lurker
  • 1,509 posts
Posted 09 July 2012 - 06:56 PM
Good catch. If you really need one, buy a USB one like Bacon Man said, or just get a cheapo PCI one from Newegg/Bestbuy. They shouldn't be more than like $10 on Newegg, can't say for sure about Bestbuy.
xfire-stix9693
Steam - slygathore
#7 Blade of grass
Blade of grass
  • 3,225 posts
Posted 09 July 2012 - 08:29 PM
Um, I have NEVER seen a modern mobo without on board sound, sorry, I don't think it exists, even my (7?) year old computer with a 7 year old mobo has on board audio.
Plus, most/almost all have front panel audio so even if the back panel isn't working, this should.
But, if all else fails, buy a USB sound card, but a PCI would be better.
#8 The Bacon Man
The Bacon Man
  • 4,201 posts
Posted 11 July 2012 - 10:23 PM
It could be bad, not working, etc.
