Bob Long Vice Help
#1 JJ12
JJ12
  • 165 posts
Posted 09 July 2012 - 02:53 PM
Just got a bob long vice, and i was wondering, do you need a low pressure tank for the vice? and is dow 55 100% necessary for the time being? (unitl i get dow 55?)
#2 DaCrazyGinger
DaCrazyGinger
  • 642 posts
Posted 21 July 2012 - 11:53 AM
If you want the best performance run a low pressure tank, but it will work on any pressure. I ran my old vice on High pressure for years.
Dow 33 or any other paintball lube, not oil, will work fine intill you get dow 55.
#3 510waffles
510waffles
  • 1,767 posts
Posted 22 July 2012 - 07:50 PM
dow55 is not neccesary but is required for peak performance. you will get some inconsistencies with other lubes.
and any tank will work. LP will just give you more efficiency.
