T8 problems!
14 replies to this topic
#1 spisla
spisla
    I made Mr. Rogers eat paint
  • 7,192 posts
Posted 22 July 2012 - 07:02 PM
so, I had an irritating and depressing day. My T8 has been giving me problems. I was at the field today, when it decides to leak from the relief valve in the middle of the first game. Thought okay, no biggie I'll download the manual, I remembered seeing something about it. Tried to Adjust the screw in the back and it did virtually nothing. Okayy I thought, I guess I'll just strip it down and try to see if any o-ring are damaged.
This happens to be at a woodsball field, and my first time taking it apart. I wasn't thinking. Wellll I ended up opening the trigger assembly. It eventually got to the point where I didn't know how to put it back together. So, I played with a friends gun for the rest of the day (all of about 3 or 4 games...) and when I got home, watched a couple videos and looks at the manual on how to put it back together.
Well, I got it back together with no parts laying out like I did at the field. I noticed I kind of messed up one of the springs, but the trigger still returned just fine. So, I decided to test it. I put a fresh cartridge in the mag and oh! no leaks. Cool. Eject the mag, Put some paint in it, and go outside. I put the Mag in, and the leak started again. huh? So I tried shooting it to see if that would stop it, and it didn't shoot. Yes, safety off.
So, no I'm sitting here, pissed off, waiting for the video to upload so you guys can see and hopefully help me. If anyone knows what I did wrong, besides being an idiot, please help me. If anyone could make a dis-assembly/re-assembly (including the trigger assembly) video, I would love you. I'm lost here, I'm ready to give up. I don't know what's going on, because it worked fine just a few weeks prior... Please help me guys :(
#2 MZinCamo
MZinCamo
    OG
  • 8,962 posts
Posted 22 July 2012 - 07:04 PM
Did you push the bolt forward before putting the trigger grouping back on?
#3 spisla
spisla
  • 7,192 posts
Posted 22 July 2012 - 07:06 PM
Pushed it forward, got it shooting. Still leaks though...
https://www.youtube.com/watch?v=fUVTuzaaeqY
so, I got it shooting, but the leak IS still there. How do I fix it?
Edited by spisla, 22 July 2012 - 07:23 PM.
#4 MZinCamo
MZinCamo
    OG
  • 8,962 posts
Posted 22 July 2012 - 07:26 PM
I'm unsure. Mine (T8.1) had this problem in a game the other day. I simply started wacking it against stuff and it worked. So I don't know haha.
#5 spisla
spisla
  • 7,192 posts
Posted 22 July 2012 - 07:30 PM
Well thanks for the help anyway! I got half the problems fixed lol...
#6 MZinCamo
MZinCamo
    OG
  • 8,962 posts
Posted 22 July 2012 - 07:33 PM
Where exactly is it leaking from?
#7 spisla
spisla
  • 7,192 posts
Posted 22 July 2012 - 07:36 PM
The screw/hole thing area right in the back of the gun. Not the velocity adjuster, but the one right in the center of the, I guess what would would be the body of the gun.
#8 -Taz-
-Taz-
    Mahna Mahna!
  • 1,141 posts
Posted 22 July 2012 - 07:48 PM
Protip: Don't take shit apart at the field, it makes it harder for me to shoot you. Also, ever try teflon tape?
Don't Be A Chump! Buy a Pump!
"Oh my god! Zombie Horses! We'd be fucked!"
#9 spisla
spisla
  • 7,192 posts
Posted 22 July 2012 - 07:49 PM
We don't have any. Good idea though...
Also, I know, I'm really hard to shoot. You're pretty easy to shoot in the top of the mask though ;):P :dodgy:
Edited by spisla, 22 July 2012 - 07:50 PM.
#10 MZinCamo
MZinCamo
    OG
  • 8,962 posts
Posted 22 July 2012 - 08:05 PM
Try unscrewing the back block and reassembling it. Check the oring on the back valve.
#11 spisla
spisla
  • 7,192 posts
Posted 22 July 2012 - 08:10 PM
do yo have to completely take the gun apart to get it off? That's always a PITA...
#12 ShadowZero
ShadowZero
    Karma Police
  • 4,269 posts
Posted 22 July 2012 - 08:18 PM
Yes, it does sound like an o-ring issue. Do you have an o-ring rebuild kit? You should try rebuilding/re-lubing every o-ring.
#13 spisla
spisla
  • 7,192 posts
Posted 22 July 2012 - 08:23 PM
I just relubed an Oring in the relief valve, which SEEMS to be the problem..
#14 spisla
spisla
  • 7,192 posts
Posted 22 July 2012 - 08:42 PM
okay, It's working now, no leaks. I guess it just really needed some lube. I take it oil doesn't work? I used dow33 on the O-ring, and now it works.
#15 MZinCamo
MZinCamo
    OG
  • 8,962 posts
Posted 22 July 2012 - 08:43 PM
You aren't supposed to oil the bolt, but use dow33 or similar grease on the powertube inner oring.
Basically, watch the Tiberius tech videos.
