Help fix a leak
5 replies to this topic
#1 tallsmallboy44
Posted 29 July 2012 - 01:45 PM
So today I was out at my field, and my DP G4 began leaking out of the back cap. It has never done this before. It has worked flawlessly for 6 months. I have tried changing O-rings and relubing the o rings, and it continues to leak. I don't want to get rid of it, so please don't say trash it, and buy an axe.
#2 Steel546
Steel546
    Drupaler.
  • 764 posts
Posted 29 July 2012 - 09:08 PM
Trash it and buy an Axe...
Just kidding. Try turning your reg all the way down, turn it on and gas it up, then slowly turn your reg back up. In my experience, DP regs are notorious for being crappy.
#3 Klub
Klub
    i haz a pickle
  • 4,975 posts
Posted 29 July 2012 - 09:42 PM
Make sure it is screwed on all the way, replace the backcap oring. If it still leaks, you can always wrap the threading in teflon tape.
#4 Robot85
Robot85
    Paper has no corners
  • 3,000 posts
Posted 29 July 2012 - 09:48 PM
Did you get the backcap oring as well, or just engine orings?
CQB Paintball
Speedsim Media
#5 tallsmallboy44
Posted 29 July 2012 - 10:44 PM
Thanks for the help. I will try to fix it tomorrow.
#6 510waffles
510waffles
  • 1,767 posts
Posted 29 July 2012 - 11:25 PM
Throw it away.
