Ion XE Feed Neck Help
11 replies to this topic
#1 Ultravapor
Ultravapor
  • 39 posts
Posted 31 July 2012 - 05:31 PM
Hey so I have an Ion XE, and from everything I've read, and from watching the Ion upgrade show of the death, I've learned that the Ion XE is supposed to take the NXT Shocker threaded feed necks. I bought a clamping feed neck from custom products, and it it's too small for the threads. The feed neck just spins around in the threads. Clearly the wrong size, but I don't understand how that could be, any advice would be more than welcome. Sorry in advance if this topic is in the wrong Thread.
#2 kingJurzy
Posted 31 July 2012 - 05:32 PM
I am sure that they use ION XE threaded feednecks.
#3 Ultravapor
Ultravapor
  • 39 posts
Posted 31 July 2012 - 05:34 PM
http://store.customp...06&categoryID=5 That's the clamping feed neck I ordered, and in the thread section right on the page, the Ion XE is listed under NXT.
#4 kingJurzy
Posted 31 July 2012 - 05:36 PM
Are you sure you have an XE? It should work.
#5 Ultravapor
Ultravapor
  • 39 posts
Posted 31 July 2012 - 05:38 PM
Positive, I have the box for it and everything, plus it has the bolt-out-back design.
#6 kingJurzy
Posted 31 July 2012 - 05:43 PM
Check to see if the threads look the same from the old one to the new one.
If not, e-mail the company and get a replacement.
#7 Ultravapor
Ultravapor
  • 39 posts
Posted 31 July 2012 - 05:46 PM
They do the not at all, the one I just got is way smaller compared to the one that came with the Ion.
#8 kingJurzy
Posted 31 July 2012 - 05:55 PM
Then return the feedneck
#9 Ultravapor
Ultravapor
  • 39 posts
Posted 31 July 2012 - 06:11 PM
Alright thank you for the help.
#10 Hitman2513
Hitman2513
    Save a Rock Throw a Mini
  • 5,995 posts
Posted 31 July 2012 - 06:25 PM
Wait so it screws in but wiggles around in the threading?
Bitches love my Spyder Ion
#11 Ultravapor
Ultravapor
  • 39 posts
Posted 31 July 2012 - 06:27 PM
It doesn't screw in period, it's just way too small, I was just confused as to why, as it is the ion xe, and the feed neck is labeled NXT threaded, and yet it doesn't fit.
#12 Hitman2513
Hitman2513
  • 5,995 posts
Posted 31 July 2012 - 06:30 PM
Yeah send it in. I was about to say Teflon tape it but never mind.
