stock class help
#1 CPS
CPS
  • 1,436 posts
Posted 04 August 2012 - 04:10 PM
Hello everyone i am thinking of selling my current marker and hopper to go modified stock class! the only problem is i am having a hard time on deciding which marker will work the best for modified stock class. my budget is 300ish. thanks
#2 The-Phantom
The-Phantom
    Rock N' Cock
  • 3,258 posts
Posted 04 August 2012 - 04:26 PM
I think phantoms fit really well in that range... for that price you can get a VSC with a .45 grip and then remove your bucket changer, slap an ASA reducer on there, and run macroline down to an ASA all for just about 300 bucks and have an amazing MSC set-up (only thing is I'd get detent rings, from mike directly at CCI, do a tape/nail polish mod in the breach, or get your barrel bored out to accept freak inserts as to prevent roll-outs/partial roll-outs)
www.phantomonline.com/
$288 for the gun
http://www.airsoldie...Code=CCIPHANTOM
$5.60 ASA reducer
$18 bottomline
http://www.macroline...-selection.html
$5 macroline (cut to your desired length on you're own
if you need to find fittings you can look through oringmonkey
http://www.oringmonk...p?cPath=210_224
PM me if you have any questions... if you don't like this set up, there are SEVERAL other options, that can be done cheaper or differently (sometimes pricier, but I can help you find what you'd like when it comes to phantoms)
it will look something like this (I believe this is superG91's phantom)
Please feel free to private message me if you have a question about something I've posted!
-Brett
#3 Duybuin
Duybuin
  • 153 posts
Posted 04 August 2012 - 05:31 PM
Used phantoms are also pretty cheap at the moment going as low as $100
#4 The-Phantom
The-Phantom
    Rock N' Cock
  • 3,258 posts
Posted 05 August 2012 - 01:11 PM
...where?
-Brett
