Azodin Pump Problems
11 replies to this topic
#1 David A.
David A.
  • 736 posts
Posted 13 August 2012 - 01:32 AM
My son just purchased a used Azodin Kaos Pump for cheap, now we see why. It's shoot OK for three or four shots, then it looses most of it's velocity for a couple shoots, then poops out completely...then after sitting a few minutes it shoot OK for a few shots then the cycle starts again? Bad regulator? Your help will be appreciated.
Edited by David A., 13 August 2012 - 08:16 AM.
My Markers:
CCM T2 (x2), CCM Series 5 (x4), CCM Series 6, CCM SS-25 (x2), Bob Long MVP, WGP Karnivor Sniper, WGP '03 Vertical Feed Sniper, WGP '05 Black Magic Sniper, WGP 2K RF Sniper, FreeFlow Lotus Sniper, CCI Phantom, Palmer Blazer, Empire AXE.
#2 kingJurzy
Posted 13 August 2012 - 01:42 AM
Check the regulator?
#3 Bravotv
Bravotv
    Take a picture, it will last longer
  • 1,396 posts
Posted 13 August 2012 - 01:48 AM
it shoots fine, then stops, what kind of air input are you using?
Viagra, lubricant, and pornographic movies? If that package arrived at my house, I'd be calling a babysitter and making reservations at the Marriott
Feedback 1/0/0
#4 Dragon1291
Dragon1291
    Dragon1291
  • 1,236 posts
Check the regulator
If that's not it then I suggest just breaking down the entire marker and cleaning/inspecting each part.
#5 pb=life
pb=life
    I like penguins
  • 8,135 posts
Posted 13 August 2012 - 01:49 AM
how much time are you giving between shots? If it's very rapid it may be the valve. Try shooting, waiting 5 or so seconds, shooting, waiting, shooting etc etc. If that works you may need to replace the valve.
#6 Bravotv
Bravotv
  • 1,396 posts
Posted 13 August 2012 - 01:57 AM
AKP Manual: http://www.azodin.co.../KP _MANUAL.pdf
Feedback 1/0/0
#7 David A.
David A.
  • 736 posts
Posted 13 August 2012 - 08:09 AM
HPA, a 45/4500 tank with a Ninja Regulator. This is the same tank he uses on his ETEK w/o problems, so it is not the air source.
If we wait a few minutes it works, sometimes...
My Markers:
#8 Original Gangsta
Original Gangsta
    My name is a lie.
  • 2,698 posts
Posted 13 August 2012 - 08:10 AM
I suggest talking to Azodin's customer service, they'll be able to set you straight.
That being said, this does sound a bit like a valve or reg problem.... Still, I would contact Azodin.
#9 Old Dude PB
Old Dude PB
    Safety third.
  • 1,642 posts
Posted 13 August 2012 - 08:27 AM
Swap in parts from the Etek to narrow it down. I'd unscrew the reg/grip from the vertical ASA, and replace it with the reg from his Etek (I think they use the same threading). Try shooting that arrangement. If the problem goes away, then you don't have to worry about the valve, springs, or any other parts internal to the gun. If it persists, you know the problem is inside the gun's body. (Note that the Etek and Kaos operate at different pressures, so you'll need to adjust the Etek reg accordingly.) Obviously, if the Etek's reg is threaded differently, this won't work.
#10 David A.
David A.
  • 736 posts
Posted 13 August 2012 - 10:39 AM
I think that is some GOOD advice, I will call them this morning.
Edited by David A., 13 August 2012 - 10:41 AM.
My Markers:
#11 David A.
David A.
  • 736 posts
Posted 13 August 2012 - 09:02 PM
Update - called Azodin customer service, spoke to Sergio in their technical department, he listened to what I said, diagnosed it as a regulator problem; either out of adjustment or broken. He gave me some instructions on how to adjust it, said if that did not work to send it in and they would fix it and send it back, at no charge.
Ends up the regulator was way out of adjustment, seems to be working fine now.
While Azodin may sell lower end, beginner markers, I have to say, I am very impressed with their customer service and response to a customer problem...High-end service!
My Markers:
#12 pb=life
pb=life
    I like penguins
  • 8,135 posts
Posted 13 August 2012 - 09:04 PM
They have pretty shoddy quality control in their electro department but both versions of the kaos are really nice guns and I agree, they do have amazing cs. One of my top 5 favorite companies cs wise.
