Problem with WGP Nightkast
#1 Håkon
Håkon
  • 63 posts
Posted 03 September 2012 - 06:15 AM
Hi,
I'v just gotten my WGP Nightkast in the post today and aired it up just now. I can hear its leaking from the regulator but can't stop the problem. (It looks like the leaking is coming from the hole in the pic.)
Any suggestions? Im not really well known with pumps just so you all know
Thanks
Edited by Håkon, 03 September 2012 - 06:16 AM.
#2 slinkyaroo
slinkyaroo
  • Root Admin
  • 4,896 posts
Posted 03 September 2012 - 07:36 AM
Usually that means to replace an oring in the reg. Sometimes sending some oil through the Asa and dry firing helps if it's dry.
#3 YoungGun32
YoungGun32
  • 1,465 posts
Posted 03 September 2012 - 02:34 PM
Sounds like an o-ring to me, pretty basic fix.
#4 Håkon
Håkon
  • 63 posts
Posted 03 September 2012 - 05:05 PM
Thanks for the reply, but one thing. How do i open the regulator (looks to me like a black magic regulator) ? I'v taken it off the gun but dont know how to get into the regulator. Any suggestions?
And, as you can see on the picture its leaking from the little hole.
Edited by Håkon, 03 September 2012 - 05:39 PM.
