2011 G6R firing problem
#1 Grayson
  • 1 posts
Posted 14 September 2012 - 04:06 PM
Hi guys, I have a G6R that's recently developed a problem where it wont full cycle and I'm trying to drbug it but I'm running out of ideas. I've cleaned and lubed the entire gun including the LPR where I thought the problem was coming from. I've got the LPR and HPR set to right around recommended pressure, I've got a new battery in it, and it still inst fully firing correctly. All the Setting on the board are default except for the fire mode which is in PSP ramping. And here is a video showing the problem: (Youtube Link)
If you guys have any ideas at all I'd love the help to try and work this out. Thanks in advance!
Edited by Grayson, 14 September 2012 - 04:13 PM.
#2 juit
  • 136 posts
Posted 14 September 2012 - 10:36 PM
looks like a blown noid
you need to correct thay hp bypass
Edited by juit, 14 September 2012 - 10:37 PM.
I love this sport!
#3 kingJurzy
Posted 14 September 2012 - 10:40 PM
What is the OP of the tank reg?
#4 510waffles
  • 1,767 posts
Posted 15 September 2012 - 12:09 PM
poppet is misplaced. reposition the poppet.check your rear ram cap that it is on properly.
Thats assuming if your pressures are correct and your gauges are in perfect condition. replace your gauges when you get the time
Edited by 510waffles, 15 September 2012 - 12:11 PM.
