Intimidator Alias Problem
7 replies to this topic
#1 The Paint Dude
The Paint Dude
  • 21 posts
Posted 06 October 2012 - 01:45 PM
Ok so I have gotten a hold of a gen 3 intimidator and when trying to fire it noting happens just a click from what I assume would be the solenoid and micro-switch. When you air the marker up the bolt instantly goes back past the milling about a 1/4in and you can push forward on the bolt slightly and let go then it will fire but not with enough air to propel a ball. And you get a * on the board meaning there is an error with the eyes.
Things i've tried:
2 new different batteries
full tank of hpa
adjusting hpr and lpr
cleaning the eyes
#2 Antonious
Antonious
    Forever Lurking
  • 6,876 posts
Posted 06 October 2012 - 02:00 PM
Does it shoot when you turn the eyes off?
I had a similar problem with mine, but it still shot when I turned the eyes off. Buying a new set of eyes ended up fixing it for me.
BST Feedback 21/0/0
#3 Phoenix01
Phoenix01
  • 181 posts
Posted 06 October 2012 - 02:37 PM
Have you opened the left side of the frame to ensure that the low pressure hose is routed without any kinks in it? Like mentioned before, let us know if you can fire it with the eyes off or not.
#4 The Paint Dude
The Paint Dude
  • 21 posts
Posted 06 October 2012 - 04:33 PM
No kinks and when you try firing it with eyes off it will shoot air out throwing the ball out maybe 20 feet then it wont do anything unless you push the bolt forward for a second and then trying to shoot again it does the same thing
#5 The Paint Dude
The Paint Dude
  • 21 posts
Posted 06 October 2012 - 05:05 PM
Edited by The Paint Dude, 06 October 2012 - 05:08 PM.
#6 Antonious
Antonious
    Forever Lurking
  • 6,876 posts
Posted 06 October 2012 - 05:54 PM
What's your LPR set to?
BST Feedback 21/0/0
#7 The Paint Dude
The Paint Dude
  • 21 posts
Posted 06 October 2012 - 06:07 PM
Like I said in first post i've adjusted it and its at about 75
#8 The Paint Dude
The Paint Dude
  • 21 posts
Posted 07 October 2012 - 08:07 PM
Ok I have solved my own problem and I definitely feel like a complete idiot and I don't expect anyone else to have this problem but if anyone cares/does have this issue the bolt pin has a small slot in the ram it has to fit in so it at most will be a 1/16in passed the body. And to my own defense a little bit having gotten this gun through eBay and seeing it for the first time the milling is just so much sexier than the GoG eXTCy that adrenaline is just pumpin through crap like that gets by ya. Shoots like a dream I might add also.
