carter machine pump kit
8 replies to this topic
#1 Pump Player
Pump Player
    Voted techpb's #1 sloth
  • 929 posts
Posted 13 October 2012 - 08:24 PM
i am lucking at a pump kit and i like the looks of the carter machine one. it has a nice handle and aluminium guide rod. http://www.paintball...camaaupuco.html
#2 The-Phantom
The-Phantom
    Rock N' Cock
  • 3,258 posts
Posted 15 October 2012 - 04:36 AM
reminds me of the hooptie design
http://paintballgate...hobapukit2.html
similar 'engineering' both probably operate functionally very similar.
I have experience with the hooptie, and think it is a very nice kit for the price. Based on all Earon's other work I've experienced, I'd say this can only be a step up from the hooptie, however minor or preferential it may be, I can only imagine this being a good quality product based off all of the mans other work... I'm buying into his 'brand' with this assumption yes, but base on appearance as well, it looks simple and effective
Please feel free to private message me if you have a question about something I've posted!
-Brett
#3 drg
drg
  • 852 posts
Posted 15 October 2012 - 02:32 PM
Both of those designs are also known as the "WGP" or stock design <_<
Anyway both look like nice basic pump kits, which first and foremost must look and feel good to the user, so I say go with it.
Keep your pump hand strong!
HawaiiPB/PumpPB - Our videos
#4 crich775
crich775
  • 218 posts
Posted 16 October 2012 - 08:03 PM
A pump kit is a pump kit is a pump kit.
All you pay for is different materials(metal vs. composite) and build quality, they all do a fairly simple operation.
I have a WGP sniper kit that's probably over a decade old and it still works perfect, and it was iirc 30 new, and I got it 20 used.
Rest In Peace Jacob Espindola 1-12-07
OEF Vet 2011-2012, Combat Infantryman Badge Recipient
#5 drg
drg
  • 852 posts
Posted 16 October 2012 - 10:23 PM
Not exactly, kits with stabilizer rods or dual rods are markedly different from those without.
#6 crich775
crich775
  • 218 posts
Posted 18 October 2012 - 11:31 AM
They all the same, very basic thing.
#7 drg
drg
  • 852 posts
Posted 18 October 2012 - 02:30 PM
No, certain design differences do make significant differences -- stabilizers, dual rods, guide size and material, air passages for mini kits, etc.
All paintball guns do the same thing, but no one would suggest there is no practical difference between them; same situation here.
Edited by drg, 18 October 2012 - 02:31 PM.
#8 Rock out w/your cocker out
  • 632 posts
Posted 18 October 2012 - 02:45 PM
DRG is right. The primary difference between a CCM deluxe and standard kit is that one has dual rods, and one does not. Depending on how one plays, the kits may feel completely different b/c of the pump handle twist/bind that the standard kit allows.
#9 ukrainiannewb
ukrainiannewb
  • 158 posts
Posted 23 October 2012 - 06:53 PM
i have this pump kit on an ans gx5. im not a big fan. i would dish out the extra money and buy a pump kit with some guide rods.
bob long g6r
Philly Dissent
-Proudly sponsored by ansgear.com
