Refilling air tank problem
12 replies to this topic
#1 DpFXfusion
DpFXfusion
  • 35 posts
Posted 23 October 2012 - 05:34 PM
I live about 45 minutes away from my paintball field and there arent any paintball shops in my area. Are there any other places bysides my field and paintball shop where i can get my Compressed air tanks filled??
#2 Tick
Tick
  • 1,197 posts
Posted 23 October 2012 - 05:36 PM
scuba shop
#3 DpFXfusion
DpFXfusion
  • 35 posts
Posted 23 October 2012 - 05:37 PM
scuba shop
Okay thanks
#4 GeezusPB
GeezusPB
    Stud Muffin
  • 610 posts
Posted 23 October 2012 - 05:39 PM
Scuba shops and some (not all) hardware stores can
Edited by GeezusPB, 23 October 2012 - 05:39 PM.
#5 DpFXfusion
DpFXfusion
  • 35 posts
Posted 23 October 2012 - 05:40 PM
Alright thanks a lot that really helps
#6 GeezusPB
GeezusPB
    Stud Muffin
  • 610 posts
Posted 23 October 2012 - 05:42 PM
Welcome bro
#7 Irish725
Irish725
  • 3,913 posts
Posted 23 October 2012 - 05:48 PM
Can't some fire stations fill up HPA tanks too? Or was that just a myth like Bigfoot or Ben Affleck being good at acting?
#8 Wolferam
Wolferam
  • 286 posts
Posted 23 October 2012 - 06:02 PM
Well, there is no bigger myth than Ben Affleck being a good actor. But, I'd call around town and see whose able to fill. Definitely start with scuba shops, fire depts and fire fighter supply companies.
#9 Razgriz183
Razgriz183
    rAwR!
  • 2,421 posts
Posted 23 October 2012 - 07:00 PM
Fire departments have trucks that full to 5k but they don't have the same fittings that a paintball tank uses, my field uses a fire engine compressor and they had to convert the fittings
my feedback :) 16/0/0
www.zephyrpaintball.com
www.OringMonkey.com
www.santaclarapaintball.com
#10 slinkyaroo
slinkyaroo
  • Root Admin
  • 4,898 posts
Posted 23 October 2012 - 08:01 PM
Fire stations may fill scuba tanks. Often just up to 2500psi (steel tanks.) I used them in the past.
#11 Joeypb
Joeypb
  • 12 posts
Posted 23 October 2012 - 08:59 PM
Possibly a sports authority but before you go call and ask off they fill hpa
#12 Spider200081
Spider200081
    Member-608 Spartans Dubuque, IA
  • 1,894 posts
Posted 23 October 2012 - 11:10 PM
Biggest one to check is for a fire equipment company. If you don't know who does the servicing for businesses in your area, talk to the manager/owner of some of your restaurants. They likely will know which company handles it. They can just look at the service tag on their fire extinguishers. Usually these companies can fill hpa tanks to atleast 3k. If they are too far from your house buy a scuba tank and then have them fill that and you can simply cross fill to your hpa tank. You will get 10-12 fills on a 68 cu in tank before the scuba hits around 1k.
#13 TECHDP=)
TECHDP=)
    I'm never online anymore.
  • 8,876 posts
Posted 24 October 2012 - 12:46 AM
Athletic good stores like Sport Chalet, Sports Authority, Big 5 etc
