ego 7 problems.
9 replies to this topic
#1 NoOne
NoOne
  • 49 posts
Posted 04 November 2012 - 10:15 PM
My ego 7 that I got recently is acting up… during the day it works awesome drops lanes like a boss, but when it gets colder/darker it breaks balls like no other or it just doesn't get the ball through the barrel… any solutions or reasons why this is happening
#2 Silyputy
Silyputy
    Senior
  • 422 posts
Posted 04 November 2012 - 10:19 PM
im not expert by far but is it the paint and the cold cuz my gun does kinda the same thing the colder it is the more i break paint. what fps is your gun chronoed at?
If they talk shit, make them eat it.
#3 NoOne
NoOne
  • 49 posts
Posted 04 November 2012 - 10:22 PM
Around 275
#4 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 04 November 2012 - 10:26 PM
check your detents, check your LPR pressure, and make sure you are using decent paint.
Egos almost NEVER break paint. that was what got them so popular when they were released.
KPS Paintball • VCU Rams • Richmond Rage
If you need help with a Dye gun, PM me!
#5 NoOne
NoOne
  • 49 posts
Posted 04 November 2012 - 10:36 PM
My lpr screw is flush with the lpr cap… the paint is custom empire pant that I have to use at the feild I go ton… and my detents are ok I was going to buy some more tomorrow
#6 gibbeepbroxzor
gibbeepbroxzor
  • 1,347 posts
Posted 04 November 2012 - 10:50 PM
Cold makes your paint more brittle=more breaks. Also, if you haven't serviced your rammer in FOREVER, you may be having some rammer stick in the really cold temps, causing it to not shoot properly.
#7 NoOne
NoOne
  • 49 posts
Posted 04 November 2012 - 10:59 PM
I clean my gun regularly (including the rammer) and my friends are using the same paint as me (some are using popits and some are using spoolies) but they haven't had any ball breaks except my friend with a bl victory v1.
#8 Rotozip2
Rotozip2
    BRO do you even autococker?
  • 3,432 posts
Posted 04 November 2012 - 11:04 PM
The older egos had a REALLY fast rammer speed that was really rough on well, everything lol. Lower your lpr and raise your dwell.
#9 Pakistani
Pakistani
    www.AliZaman.com
  • 2,237 posts
Posted 05 November 2012 - 02:03 AM
good old empire custom.
watch this:
http://youtu.be/-DLzb0QPPQA
Edited by Pakistani, 05 November 2012 - 02:04 AM.
#10 NoOne
NoOne
  • 49 posts
Posted 05 November 2012 - 05:40 PM
The only thing is that even at night my friends don't break paint o.0
