Seeking advice regarding tank
11 replies to this topic
#1 TD_R
TD_R
  • 5 posts
Posted 15 November 2012 - 11:08 PM
I recently purchased an A-5 with a response trigger. Need advice on which tank to purchase to fully utilize the RT and its benefits. Specifically for this gun only.
#2 TacticlTwinkie
TacticlTwinkie
    *insert witty title*
  • 3,974 posts
Posted 15 November 2012 - 11:11 PM
A ninja tank with the SHP regulator.
#3 kingJurzy
Posted 15 November 2012 - 11:15 PM
I would not get a SHP tank because they are hard to sell and they are not recommended to use on most other markers.
#4 TacticlTwinkie
TacticlTwinkie
  • 3,974 posts
Posted 16 November 2012 - 12:07 AM
but he said for that gun specifically.
If you do want to use this tank for other guns down the road, a standard ninja reg with the adjustable setting to the highest output (850psi i believe).
#5 TD_R
TD_R
  • 5 posts
Posted 16 November 2012 - 12:43 AM
thank you for your comments.
as far as the tank, there are different sizes and psis. i have google searched for hours and cant seem to find a consensus best pick.
#6 TacticlTwinkie
TacticlTwinkie
  • 3,974 posts
Posted 16 November 2012 - 12:49 AM
When in doubt, go with the 68/4500. It's widely regarded as the go-to tank size. It's good for averaged height players (5'8"-5'11") for a shorter player, a 45/4500 may be more ideal. For a younger player or female player, or those who like a really tight setup, a 50/4500 may be another to consider. And for our taller friends or players with long arms, a 90/4500 is nice.
Edited by TacticlTwinkie, 16 November 2012 - 12:49 AM.
#7 bassfisher
bassfisher
  • 2,100 posts
Posted 16 November 2012 - 01:25 AM
I would go 68/4500, if you get a 3000 psi tank you'll run out of air pretty fast if you're on the trigger a lot.
Carolina Riot Scenario Team
#8 TD_R
TD_R
  • 5 posts
Posted 21 November 2012 - 10:33 PM
thank you everyone who has answered thus far. I am 6ft so i believe the 68/4500 seemingly would be ideal size for me.
Ninja tank with the regulator? Would the consensus be that is the best for my setup? From reading online i see ninja and i believe guerrilla are the two most popular choices.
Does anyone have a strong case for or against on either? And is the regulator a necessity for my gun?
#9 kingJurzy
Posted 21 November 2012 - 10:42 PM
Ninja is the best. They have a user serviceable regulator and the output pressure can be adjusted.
Edited by kingJurzy, 21 November 2012 - 10:42 PM.
#10 TD_R
TD_R
  • 5 posts
Posted 23 November 2012 - 08:26 AM
thank you, looks like i will be going with a 68/4500 ninja.
Would ordering directly from the website be my best/only option?
#11 Pump Player
Pump Player
    Voted techpb's #1 sloth
  • 929 posts
Posted 23 November 2012 - 08:38 PM
all the websites have them. check local shops, i got a ninja 45/4500 today for 150, although most websites have them for 165
#12 TD_R
TD_R
  • 5 posts
Posted 25 November 2012 - 11:30 AM
thank you for all your help
