Will a heavy tank mess up my ASA?
13 replies to this topic
#1 Bigman3
Bigman3
  • 105 posts
Posted 28 November 2012 - 06:39 PM
Alright, I'm looking at a steel HPA tank online and was wondering if the weight of it would basically rip the threads off a gun. The tank is approx. 3lbs.
#2 kingJurzy
Posted 28 November 2012 - 06:45 PM
No. I do not recommend starting off with a 3000. Save money and buy a 4500 psi tank.
#3 Bigman3
Bigman3
  • 105 posts
Posted 28 November 2012 - 06:51 PM
That was not even close to what I asked
#4 Tick
Tick
  • 1,197 posts
Posted 28 November 2012 - 06:57 PM
When I ref and fill tanks up at my field, I do notice that the 98's ASA's so start to wiggle and come loose after a while with their 3K HPA tanks. But, they are not stripped and all I do is tighten them back up and they're fine.
#5 G4paintballer
G4paintballer
    Gun/gear whore
  • 5,862 posts
Posted 28 November 2012 - 07:01 PM
Since I used a 90/4500 on my phantom once, you'll be fine. And to give you an idea the 90/4500 was like 4lbs, my phantom was less than 2lb's.
Feedback 10/0/0
#6 kingJurzy
Posted 28 November 2012 - 07:33 PM
If you look closely, I answered your question.
In case you cannot find it I will make it stand out a little.
Edited by kingJurzy, 28 November 2012 - 07:33 PM.
#7 misterkyle
misterkyle
  • 1,059 posts
Posted 28 November 2012 - 07:41 PM
this is correct, just save up and get a 4500.
#8 sameagol26
sameagol26
    I am BTDeltafan101
  • 5,052 posts
Posted 28 November 2012 - 07:53 PM
You will be fine. If the asa gets loose, just tighten the two screws and you will be good to go again. You could always loctite it with blue loctite for extra hold.
#9 OMGPaintball
OMGPaintball
    Navy Baller
  • 944 posts
Posted 28 November 2012 - 08:28 PM
might have to tighten it back up every so often, but it shouldn't cause many problems
#10 Bigman3
Bigman3
  • 105 posts
Posted 28 November 2012 - 09:39 PM
What's wrong with the 3000?
#11 kingJurzy
Posted 28 November 2012 - 09:40 PM
Heavy, long, not good.
3000 psi tanks are not rounded off so they are not comfortable to shoulder.
#12 madsnipes
madsnipes
    CARNAGE 3!!!!!!!
  • 5,055 posts
Posted 28 November 2012 - 09:46 PM
You should be fine, but if it does get loose you can just tighten the allen keys.
#13 Pump Player
Pump Player
    Voted techpb's #1 sloth
  • 929 posts
Posted 29 November 2012 - 04:32 PM
what gun do you have? there fine for tippmann 98's (which i dont recommend) but guns like PMR's and extcy's will not do well with them
#14 cybermaniac15
cybermaniac15
  • 5,450 posts
Posted 29 November 2012 - 04:43 PM
How do you figure?
Anyways, the 3000 tank would work fine, but you are going to upgrade anyways.... Might as well save up for a 4500 tank.
