Dangerous power g3 not shooting (HELP!)
#1 Dickdix
Dickdix
    Whos Rich
  • 152 posts
Posted 29 November 2012 - 05:13 PM
i turned on my g3 for the first time in months and everything is working good like the eyes but it wont shoot. i don't even hear the little click from the board anymore. Whats my problem here? any help would be great!
Free Guwop!
#2 cybermaniac15
cybermaniac15
  • 5,450 posts
Posted 29 November 2012 - 05:56 PM
New battery?
#3 Phoenix01
Phoenix01
  • 181 posts
Posted 29 November 2012 - 05:57 PM
Have you tried pulling the trigger with the eyes off? Also when was the last time the battery was changed? That click is the solenoid, not the board.
#4 dannyboy768
dannyboy768
    TOMA ABBIATI
  • 2,028 posts
Posted 29 November 2012 - 10:40 PM
Replace the battery, check the reflector on the trigger and make sure its triggering the optical sensor. Check the connections on the board.
DIRT CHEAP CF Tanks in Hydro!
http://shop.swapmytank.com/
#5 Wrecking+Crew
Wrecking+Crew
  • 33 posts
Posted 04 April 2013 - 10:21 AM
Check the solenoid that whats makes the click sound and your battery
